Having some odd clutch issues please help
Old Feb 3, 2011
millertime1388's Avatar
millertime1388 is an unknown quantity at this point
I am newer to the civic world and i am seeking some advice. For about 3-4 months now i have been having some clutch issues. I have a 1999 honda civic DX hatchback. When i try to release the clutch in between gears or even starting out in first it feels like the clutch pedal is still compressed when it is all the way out. Ive heard the "ya your clutch is fried" but also have seen that if it was doing that i would only have a bout a week or so before it stopped working all together and it has been months now.
I am curious if anyone has a connection in replacing the clutch in denver (i know its a long shot). i just did the tranny myself and do not feel like tearing it apart again. Everyone told me to do the clutch while it was out but i couldnt afford it at the time and didnt want to mess with it... but like the saying goes "if you dont have time to do it right the first time, when are you going to find time to do it."
Also has anyone else seen this... could it be a matter of clutch pedal adjustment? Also i talked to a import tuning shop and he said DO NOT use Napa, checker, autozone clutches and that they would be nothing but problems with having to adjust things all the time. Is this true ive always used autozone clutches and never had problems in the past (on my older mustang and bronco).
Old Feb 3, 2011
MelJ's Avatar
Trance Addict
Re: Having some odd clutch issues please help
Have you bled the clutch at all? There could be air. But that would give the pedal a spongy feel.
Old Feb 3, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Maybe its short on clutch fluid? I would at least inspect the lines...
And buy your new clutch online. MUCH cheaper, and you have WAY more selection.
And Ive heard you should use OEM throwout bearings, instead of the ones that come from a kit; though I used the Exedy one that came with mine and I have no complaints..only been @1k miles or so too, so I may eat my words, lol
Old Feb 3, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
remove the rubber boot and lube the slave cylinder push pin as well then replace the boot.
Old Feb 3, 2011
MelJ's Avatar
Trance Addict
Yup. I was gonna say, as long as its a trusted aftermarket brand, you should be good. When in doubt, ask, or go with OEM.
Old Feb 3, 2011
I had picked on up from autozone already and not sure were the reciept is :-/..... i know the pin cover to my slave cylinder is jacked up and i dont even think it is on there all the way right now... i will try to lube that up here in a bit... yes i checked the fluid and it is full
Old Feb 14, 2011
Out of curiosity how muchof the slave cylinder pin (the one the disengages the clutch) should be showing when the pedal is out ..... It seems that I have 3/4 inch
juror
Jun 9, 2015 02:15 PM
crowtoo
May 11, 2015 06:50 PM
markp94
Apr 30, 2015 09:19 PM
bsmiley
Apr 27, 2015 01:27 PM
Sparty
Transmission
Jan 22, 2002 03:41 PM
