Quick Question: Pressure Tesing
Old Jan 11, 2011
ThorOtheBIG's Avatar
ThorOtheBIG is an unknown quantity at this point
Hey guys I read in a search that 90psi across all cylinders was too low for the car to run and that the compression tester might be incorrect. I hope my tester is correct but my readings were pretty much 90psi across the board. Anyone else know if at 90psi it would not run?
Also, I would like to know the proper amount of pressure to use on the cooling system when testing. I read 16psi from a parts store online. Will 16 be too much for the system?
Thanks guys!
Old Jan 11, 2011
Re: Quick Question: Pressure Tesing
is the engine running bad?
Old Jan 11, 2011
90 is low but the car could still run, just not have much power. 130psi is around normal. its strange that all four are low and the same, unless maybe the tester is messed. if the car drives normally, then i doubt the readings are correct.
Old Jan 11, 2011
my thoughts exactly
Old Feb 6, 2011
leroy02's Avatar
leroy02 is an unknown quantity at this point
i did a compression test on my civic ex with the loaner tester from auto parts store all cyl
were 85 dry slightly higher with oil . I will re test with a new tester after gas test
Old Feb 6, 2011
Gsx455's Avatar
Gsx455 is an unknown quantity at this point
Did you try 5 cranks, and check the O-rings on the loaner tester?
Aug 21, 2015 05:27 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
adamdrives
15
Aug 8, 2015 08:53 PM
