What is chirping sound? 1999 civic
When I start the car, you cannot hear it. But, as soon as the engine warms up, there is a rapid, high-pitched chirping sound that comes from the engine in front of the driver's seat. It sounds like birds chirping, and it gets louder after being driven a bit. Any ideas?
Re: What is chirping sound? 1999 civic
could also be belts that are worn or not the proper tension. if it changes pitch when turning, its PS belt. if it changes with a/c being on, then its ac belt. if it changes when pressing the gas, its timing belt/tensioner. you can also narrow it down by spraying belt dressing on each belt one at a time. if the noise changes when you spray, you found the problem belt.
usajags84
15
Aug 19, 2015 03:12 AM
Linda0818
Apr 23, 2015 11:30 AM
aultman1990
Apr 19, 2015 07:14 AM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
