Paint removal options
I have just found out my little white civic HB has been painted with a 50% house paint and 50% mineral spirits. Whoever did this did a good job with a roller. I would like to remove all the paint and repaint it with car paint. I have access to a paint booth and sprayer, just would like a good way to remove this house paint. i have no idea what is under it. Door jams are still car paint so that wont be an issue. Any DIY car painters with labor free ideas would be great. I dont mind hard work, just like to minimize it if possible.
I have an appointment with the frame shop to fix the damage and core support.
Kenny the Ricer
Re: Paint removal options
Ah, the good ol' rustoleum roller method, haven't seen that in a while
I'm not completely sure, but brakefluid, acetone and mineral spirits are all paint thinners that remove some paint, but it would be a mess...
Unless you have access to a sandblaster, i think the only suggestion i have is to sand over the paint, prime it, and just paint over it
Gonna be a LOT of sanding to get everything smoothed out
Will the two different types of paint cause issues if i just sand it rough and not to the metal? i hear conflicting information about that. I have a compressor and sander to speed things up and save my arm.
Kenny the Ricer
Well, If you want to rough sand it you can, it will just take a lot of work
You'd have to sand it smooth again, primer filler, sand it again, primer sealer, sand it, paint it
Well, you could skip primer sealer if you want, but that's for best results
i'd just high grit sand the existing paint, prime it and slap on some new paint, since i doubt you're going to drive that car for the next 10 years without it breaking down
Unless you plan for it to be a show car, then maybe it's worth the extra work
Not a show car. I plan to have this car for a long time. The motor is very well taken care of with no leaks or power issues. The tyranny is solid and feels good, no play in the shifter. The suspension however is another story. This poor car has been slammed around a few times and has a bent frame, broken lower motor mount, broken passenger axle, failing bearings on the driver side, shitty shocks and ball joint. Oh yea, no muffler. For having no muffler it sounds better than my friends 97 civic with a 400$ aftermarket fart amplifier. Thanks for the input, I guess in the next few months i will just sand, sand, sand, and paint it correctly. First things first, get it mechanically sound, then make it pretty.
BootyDo
Jun 21, 2016 03:45 PM
OptimisticWay
Jul 10, 2015 04:31 PM
ballmich
Jul 9, 2015 11:59 AM
BootyDo
Jul 7, 2015 06:06 AM
