98 EX shifter problems
Old Oct 3, 2010
thuglifecivic's Avatar
thuglifecivic is an unknown quantity at this point
Ok so this car is a fixer uper fer sure. Any way here's a problem I can't figure out.
When I got the car the shifter was so loose I could barely find the gears. So I replaced the bushings underneath (front and rear) with energy susp ones and it tightened it up considerably. HOWEVER it is still really loose and wobbles a lot side to side even when in gear.. Also it tends to not catch in 4th sometimes, I have to baby it into gear. So I don't know what else to check at this point and everywhere I look on the internet says to replace bushings, which I already did!
Any help would be cool.
Old Oct 3, 2010
02civicsi02's Avatar
Low and slow!
Re: 98 EX shifter problems
I am not to sure but dont the 6th gen civics have the double or single bend shifter rods instead of the new shifter cables. If it is the shifter rod then I would check that out.
Old Oct 3, 2010
lazlong's Avatar
Take the boot off and see if it's loose only at the shifter (#2) or if #13 is loose and at least it narrows it down. If #13 is loose, try changing the rubber holders (#16, 14, 30).
http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
EDIT: Only place I've been able to get those parts with no number listed is at the local Honda house. Usually small parts like that aren't too awful expensive at the dealer.
Old Oct 14, 2010
the linkage looks fine to me. It just doesnt want to go into 4th gear unless i let off the clutch very slowly. I cant figure this out.
Old Oct 14, 2010
lazlong's Avatar
Might be 4th gear synchro. If that's the case then you might as well rebuild it as they have to take the whole thing practically apart anyways. I'll ask my friend who runs the tranny shop tomorrow and get back to ya.
Old Oct 15, 2010
Mal2000Si's Avatar
Mal2000Si is an unknown quantity at this point
i had the same problem, its the bearings in your shifter. for mine i had to get a new shifter, fixed everything. there are bearings in your shifter that connect your linkage to the bottom of your shifter!
Old Oct 15, 2010
where can i find a diy or something bc i dont know anything about the bearings. also where do you get new ones?
TuRtLE714
Jan 5, 2002 09:14 PM
Jodster
Dec 29, 2001 09:00 PM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
01civicboi
Nov 23, 2001 03:02 PM
