97 civic ex
Old Oct 1, 2010
Eliza's Avatar
Eliza is an unknown quantity at this point
97 civic ex
Okay so I'm hoping you can help me out here. With my civic, the oil level is fluctuating. I had an oil change, oil level was up a quart and a half. I drained that out and then it was up again. Thinking it was a coolant/head gasket problem (since I had an antifreeze leak as well) I took it in. There wasn't a coolant leak, it was supposidly a seperate problem with a hole in a hose. The oil problem is still there. Sometimes it's high, sometimes it's normal. The oil doesn't look weird.. I just did another oil change to see if it smelt like fuel but it doesn't, nor does it have a milky look that a coolant leak would cause. Also, does anyone know where the fuel injection port input is? It's not in plain site on the rod and that's the only thing I can think to check... If anyone has any other ideas, it would be greatly appreciated. Thank you.
Old Oct 1, 2010
lazlong's Avatar
Re: 97 civic ex
Just guessing- plugged oil filter or oil galleries?
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
