Buyers Guide... help needed
Old Sep 28, 2010
basicbone's Avatar
basicbone is an unknown quantity at this point
Here is my situation, I am looking for a 6th gen civic most likely a hatch. But most of the hatches for sale in my area are from private sellers. So heres the problem I don't know much about mechanics so what should I look for when buying from a private seller? I don't want to get scammed or be stuck with a car with major issues.
Thanks in advance,
basicbone
Old Sep 30, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
Re: Buyers Guide... help needed
There is soooooo much to look for. make sure you know what was done to the car. if the guy did mods himself make him show you EXACTLY what he did and how he went about doing them. Make sure the ignition switch is properly functioning on that car. there were well over 1 million civics recalled that year with this issue and can be very dangerous. also carfax is your friend check that out and make sure everything is good.
Old Sep 30, 2010
lazlong's Avatar
Any maintenance records? When was timing belt was done last? Check all fluids.
Old Oct 3, 2010
ac_2007's Avatar
ac_2007 will become famous soon enough
Its hard to find a car like that which wasn't abused or riced out beyond borders. Have a mechanic look at it. The $100 bucks you pay him will be well worth it. My buddy had his hatch inspected after he gave up his neon for it. Mechanic then told him it needed about $3000 in repair to the suspension alone
Check:
- Body & subframe for rust and corrosion
- Suspension (Very expensive fix)
- Timing belt
- Maintenance rocords
- Headgasket (easy to check - when the car is warm and idling, does the heat work? look at the temperature guage aswell and make sure it doesn't overheat)
mattdoc
Mar 14, 2017 12:10 PM
Myredjonda
Apr 14, 2015 07:00 PM
jonboy
Apr 13, 2015 11:11 PM
