Window Problem
Old Jan 25, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Window Problem
Okay on my '97 ex coupe, the passenger side window goes down but rolls up really, really slow...and sometimes i have to help it up. It starts to stop rolling down at about halfwaydown. I've looked through some of the posts, but is there any real fix to this? If so, please tell me what the problem is and what i can do to fix this. -Thanks guys
Old Feb 5, 2009
cornd0g's Avatar
cornd0g is an unknown quantity at this point
Re: Window Problem
same problem, especially in cold. mine starts out normally but then goes down really slowly. sometimes it doesnt even go up =\
Old Feb 5, 2009
sarahann417's Avatar
sarahann417 is an unknown quantity at this point
Re: Window Problem
If it is a windown you need im not sure on what years the range is but i would have a new window maybe if oyu ened one. I know i have one off a 89 civic I dont know if it is the same or what. let me know if interested.
Old Feb 5, 2009
TRIZ's Avatar
Re: Window Problem
That happened on my moms car... the damn window was slow as **** (toyota camery). Turns out the wire harness for the window was torn to **** on the inside of the window... really strange. I guess it wore out with all the up and down motion.
Also, maybe the motor, or a bad connection (not enough voltage)
Old Feb 6, 2009
civicplaya's Avatar
Re: Window Problem
Hmm thanks, i'll remove the panel and see if i can find any visual problems. -Will post what i found.
Old Feb 8, 2009
civicplaya's Avatar
Re: Window Problem
Sometimes the window stopped at halfway when rolling down too.
Old Feb 8, 2009
civicplaya's Avatar
Re: Window Problem
Okay the problem was it needed to be lubed. I took the door panel off and sprayed all the tracks down really good, including the window seals. Make sure you get into where the window rolls/sits. Spray everything that makes the window roll up and down, (except for the motor of course).
I went to AutoZone and bought this Liquid Wrench White Lithium Grease... works wonders, for about three bucks. =) Roll it up and down about 20 times and it should be good.
Old Feb 8, 2009
cornd0g's Avatar
Re: Window Problem
im deff gonna try that. did any grease get on the window?
Old Feb 9, 2009
civicplaya's Avatar
Re: Window Problem
a little, the red tube on in of sprayer came off so it went into full spray. =P There might be a little excess near the seals after rolling up and down a few times, just wipe the excess off and it'll be fine.
Old Feb 9, 2009
civicplaya's Avatar
Re: Window Problem
Oh first, i'd try removing the door panel and getting everything real good, then if it happens in a week or whatever, just spray it in the seals so it doesn't take as long. Just make sure you get it real good should be fine.
Old Feb 21, 2009
cornd0g's Avatar
Re: Window Problem
boo....i owned the tracks with grease. hell, the car smelled like it for days. it worked decent for a little a few days now the problem is back again. suggestions?
Old Feb 23, 2009
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
Re: Window Problem
could be the regulators
Old Feb 23, 2009
civicplaya's Avatar
Re: Window Problem
Wow yeah.......the stupid stuffed worked for a few days but now it's back to the same problem....this is getting ridiculous and i'd like to fix it before summer at least!
Any suggestions or answers would be sweet
-Thanks
Old Feb 26, 2009
JRad's Avatar
JRad is an unknown quantity at this point
Re: Window Problem
I own a 97 coupe and the drivers side window would go up very slow and i would have to help it up, so i took off the door panel and sprayed everything with WD40 and its been about three months and it still works like new, it actually goes up faster than the passenger side window now! but yeah my car smelled like WD40 for a week or two so i re opened the panel and sprayed febreeze everywhere and in my car and shut all the windows and let it sit for a while, then aired it out, that made it smell good again!
Old Feb 27, 2009
Dan Hatch92's Avatar
Dan Hatch92 is an unknown quantity at this point
Re: Window Problem
I have similiar issues with my 92. The regulators are f**ked. If thats the problem your looking at like 200 for parts and labor if it's a manual window. Auto windows could be more. Good luck.
Old Feb 27, 2009
civicplaya's Avatar
Re: Window Problem
Would it be the regulators if it actually worked great for a few days after being greased?
Old Feb 27, 2009
Re: Window Problem
Could be. Some times the regulators get bent. Sometimes the windows work fine and then other times the glass falls off the track and shatters inside your door (guess who that happened too?). Before that they were working fine with no sign of any problems and then boom, my wallet got punched in the face without warning. If they are auto windows it could be a bad regulator motor. Pull the door panel and check it out.
Old Feb 27, 2009
leegn's Avatar
leegn is an unknown quantity at this point
Who needs that much velcro?
Why would anyone need that much velcro? These guys sell it by the roll http://www.liangdianup.com/miscellaneous_1.htm and is
hook and look and velcro the same thing?
Old Feb 28, 2009
civicplaya's Avatar
Re: Window Problem
how do i check the regulator motor?
Old Feb 28, 2009
Re: Window Problem
Take the door panel off and turn your accessories on. Then try to roll down your window. At the very least you will be able to see if your regulator(s) is bent. Check your wiring as well.
Old Mar 3, 2009
civicplaya's Avatar
Re: Window Problem
What's the regulator actually look like?
-thankz
Old Mar 4, 2009
civicplaya's Avatar
Re: Window Problem
Wow, just got into the car today and tried rolling down passenger side window and the pos won't roll down. Can't even hear the motor. Anyone know what fuse it is?
-thankz
Old Mar 4, 2009
Sluggo's Avatar
Sluggo is an unknown quantity at this point
Re: Window Problem
try and fix it yourself.. power windows can be expensive to fix at dealer.
Old Mar 4, 2009
Sluggo's Avatar
Re: Window Problem
-thankz
LOL.... you have motors and regulators.... Regulators from what i understand, while trying to fix a 1965 impala... is the actual hardware.. the rails, with the gearteeth, etc etc.. and the part that holds the glass... All the hardware if i am not mistaken
Old Mar 5, 2009
civicplaya's Avatar
Re: Window Problem
Yeah, i'll try to look at it tonight and come back with what i found.
Old Mar 5, 2009
PAINT FREAK's Avatar
PAINT FREAK is an unknown quantity at this point
Re: Window Problem
you need a new window regulator and motor.
Old Mar 5, 2009
shadymechanic's Avatar
shadymechanic is an unknown quantity at this point
Re: Window Problem
Dude,at worst, you need to replace the window seal, it's probably lost its smooth texture. Don't spend big bucks just yet. Lithium grease works well on the seal of the back of the window but it does wear off so add it every few months. Don't wd-40 it because it cleans out all of the lubricants in your window components and could affect your door locks too. That stuff is not a cure-all.
If it's a 1997 why spend the money trying to make it new again.White lithium grease with a qtip first, new seal second, save your money- third-for more serious troubles.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
beveragemp
May 25, 2015 07:11 PM
timpan
May 18, 2015 07:06 AM
