Engine Light On And Off
i have a 1996 civic hatch with a d16y8 vtec and a obd1 harness and the p28 ecu. every time i hit a bump the check engine light comes on and goes off. what is worng? if the engine light comes on does it disable vtec?
Re: Engine Light On And Off
somethings messed with the wiring then. its prolly hitting metal and shorting out. i would recheck everything.
I found out the problem. After my car was serviced. I checked the Obd1 plug and they left the paper clip in when they check the engine code. It would make a connection when i hit a bump so it was flashing the code. something that easy>
Xuhme
21
Aug 7, 2023 03:40 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
