i might buy it....what do you all think.....
here it is...94 del sol with 98 Ls/Vtec swap that has been rebuilt a year ago with roughly 12,000 miles. 98 gsr trans rebuilt 3,000 miles ago......
thought i would ask all yalls opinion......
http://s143.photobucket.com/albums/r...015/?start=all
Re: i might buy it....what do you all think.....
Looks interesting. Who did the work and what is their experience with doing that type of work?
the guy didnt say who did the work on the ad...i will ask him...here is a list of a couple of mods.....
Under the hood
98 LS block
98 GSR head
98 GSR transmission
Moroso oil pan
Crower Rods
JE 11:1 Pistons
Civic SI camshafts and cam gears
New oem Valves
All seal been replaced except front main within last year
Mugen powdercoated valve cover and mugen oil cap
Vtec silenoid cover
fuse and radiator covers
powder coated strut bar
Cam seal
Interstate battery
Greddy header with 2 1/4 pipe back to exhaust
high flow cat
NGK iridium plugs replaced 6k ago
Accel 8mm plug wires
New distributor
New starter
New brake booster
New brake master cylinder
New brake proporionate valve
New clutch master cylinder
Ingen cold air intake
New serpintine belt
Skunk2 Intake manifold (older version)
racing Aluminium radiator and all new hoses and thermostat
Drivetrain/Suspension
Stage 1 exedy clutch
Fidanza 8lb flywheel
New shift forks in tranny
Polyurethane shift linkage bushings
Skunk2 dual bend short throw with Skunk2 ****
New axles
slotted/drilled rotors
new brake pads
painted calipers and drums
Skunk2 pro series fully adjustable coilover kit
Rear SPC control arms
Rear lower SPC toe rods
Lower strut bar
Under the hood
98 LS block
98 GSR head
98 GSR transmission
Moroso oil pan
Crower Rods
JE 11:1 Pistons
New oem Valves
Vtec silenoid cover
Cam seal
Interstate battery
high flow cat
New distributor
New starter
New brake booster
New serpintine belt
New axles
new brake pads
Lower strut bar
Find out what it was tunned on. He he says it's just running a generic "chip" that wasn't tunned exactly for his setup, walk away.
[QUOTE=MisterFrankieJ;4289389Find out what it was tunned on. He he says it's just running a generic "chip" that wasn't tunned exactly for his setup, walk away.[/QUOTE]
what do you mean by that......
If it was done the right way he should say somthing along the lines of "It's a chipped p28 tunned on hondata/uberdata/crome/neptune". If he says something like "It's a p28 with a "Skunk2", "Spoon", "Mugen" chip I wouldn't buy it or I would have it tunned the right way.
ok....this is his exact message.....
"The Ecu was sent off to skunk2 to be chipped and programmed."
since it is a skunk2....is that not as good....should i ask him anymore questions.....or should i just forget about the whole thing.......
The problem isn't if shunk2 is good or not. Think of it this way. If you built your own n/a lsvtec would you want to just to have your ecu chipped with a map that wasn't tunned specificly for your setup or would you want to get dyno tunned specificly to your motor.
ok.....i think i am going to take yalls advice......still....i am looking for another car.....and i stumbled across this......
"95 Integra w/ InlinePro T3/T4 Turbo Kit. 2000 Ls Motor w/ 78k. Chasis has 176k. Car is lowered, stock steelies w/ factory hub caps. Turbo Smart Dual Stage Boost Controller. Comp.Clutch Stage 5 w/ C.C. FlyWheel. Inline solid mounts. Hondata, tuning by Big Fish @ Inline. Results TBA."
what do you think....what questions should i ask him....it is still for sale........
i really like this car......it is fresh.....but i dont want to commit till i am sure.....
^that sounds much better. If my memory serves me inline pro has a good rep honda-tech. Again I'd do a compression test and see if you can dyno graph if possible (with the a/f ratio). Do you have a link to the for sale ad?
http://washingtondc.craigslist.org/n...579055272.html
Lol were looking at the same things. theres TONS of swapped civics for sale in the area, but there all LS swaps, not GS-R swaps. ugh. and they run like $6k. amazing.
o and its never been dynoed, but he "guesses" 200 whp. all 200whp of that gets a 9.6 1/8 mile. thats the wimpiest 200 horses Ive ever seen. thats like a 16sec 1/4 for 200whp. Not so much.
i also enjoyed this one: http://washingtondc.craigslist.org/n...581841475.html
It comes witha whale ***** intake, mind you.....
Official Rattlesnake Hunter
stage 5 clutch will be fun for about 3 months, before it blows or kills the tranny...
looks way better Hondata for the win!!!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
viperGTS
Jul 27, 2015 08:38 PM
