Alternator/Battery/Gauge issues
Greetings -
I have an 01 EX coupe with 112,000 miles. Here are the symptoms:
1. While driving, instrument panel and radio will cease operation.
2. After varying amounts of time (10 seconds to a few minutes) they will begin operating again. The ABS light sometimes comes on.
3. Aux power source (lighter) will sometimes remain operating.
4. Sometimes the fan will slow down or stop running.
5. Engine operation never seems to be an issue - just the devices specified.
6. Once (today) the car would not turn over. Got it started with a jump and made it home.
Once home, I checked alternator output and the battery.
1. Voltage at the battery with the engine running was 13.7 (cooling fan off) and 13.3 (fan on).
2. The battery is of an unknown age (the date punches on it are all intact). I have had the car for 4 years. (I know - the battery is certain to be ready for a replacement.)
3. Specific gravity floats 2 ***** in all 6 cells.
4. I currently have it charging at 12 amps.
My initial feeling was the alternator but I do not have any dash indication of a failure.
Would a bad battery alone cause these problems?
Is there a possible transiant problem with the alternator?
Anything else that might be causing this?
Thanx
Thanx
Re: Alternator/Battery/Gauge issues
Nothing appears to be loose. When the engine is running, (during my test today) I am getting good voltage to the battery. When the problem occurs, engine RPM has no effect on the symptoms.
To me, this is a real head scratcher. I hope someone with more experience with these cars has an idea.
Rep Power: 787 Re: Alternator/Battery/Gauge issues
make sure all the grounds are secure and the clamps on the battery terminals. they need to be tight. otherwise try a new battery. if alternator goes, the batt light will come on. seems like maybe the battery is weak and the alt is putting extra energy just to keep the car going.
1 Post
Rep Power: 0 Re: Alternator/Battery/Gauge issues
i say alternator, it should be putting out 14-14.4 volts when running, not 13.3, ur pulling low voltage, take it off, take it to oriely and have it tested on their diagnostics
i think alot of place can test alternator on the car, but idk ive gone through 4 alternators on my old car and they would either work or die.
Thanx for the input. It's been very helpful.
The verdict is in - Voltage regulator.
Final cost - $130 installed, not by me but by Fast Eddy's in Andrews, NC. I used Eddy in the past to build a HO alternator for my Typhoon. A rare combination of a smart and honest repair shop.
PiCASSO
04-23-2002 12:38 AM
droidekaus
03-18-2002 02:06 PM
RiCeGrL
02-21-2002 09:07 PM
