Is it possible to install a underlight by urself
Is it possible for a somewhat unskilled car person and couple of friends to install neons for under the car. I just ordered a kit with all the stuff i need but im not sure if this is something that has to be done profesionally done. If you guys could help me out and let me know i would appreciate it .
I wish I was asian
jus follow the directions and you should be set. nothing "really" has to be professionally done as long as you know what your doing (by reading instructions and/or using a little brain power) and as long as you have all the things u need (i.e tools) and take ur time.
I installed mine myself, no problems whatsoever, just take your time and consider all scenerios on what could happen to them when you consider placement of the neons.. I had mine done in two hours with a drill, a cordless drill with a #2 phillips screwdriver bit, some heat shrink, some plastic tubing, new self-tapping screws, a switch, some female end disconnects, a heat gun, and I think that was about it.. maybe I'm missing something but who knows, that's not the point, the point is.. have fun, don't break anything lol Did you get Street Glow Gold series? They come with a lifetime warrenty.. definitely worth the money.
If this is your first time installing neon, isuggest you work with something smaller like in dash stuff. But if you really want to install the underbody's yourself it is a very difficult tim consuming process. Especially if you don't have jackstands (heheheh). And one mor thing, unless you have a body kit installed on your car, it is going to be very difficuly to install the tubes without all of them being visible. My best advice is to just carefully plan everything out before you get started.
-Do it right, do it once.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
