8 gauge for a 4 gauge amp?
Quick question, can i use a 8 gauge power/ground wire for an amp thats 1000W? recommended is 4 gauge from what the manual says. reason i ask is i already have an 8 gauge wire and ground running thru the car. i dont feel like re-wiring the whole car again =( Any advice would be nice. Thanks in advance!
Audio manufacturers tend to chose the size of the power wires for their cosmetic appeal. If you see to 400W amps and 1 uses 4WAG and the other 8AWG, most ppl will see this and assume the one with 4awg is more powerful, not necessarily so. I see where ya comin from so do this...use your 8AWG, run the amp HARD for awhile but monitor the temp of the wire (with your hand is fine). If it gets warm at all, I would change it, if you feel no diff, don't woory 'bout it.
~Tbone
~Tbone
dont be cheap and lazy, get 4gauge and just rewire it, you'll be getting full power to your amp that way.
~tbone
Thanks for all the advice guys
. I've been talkin to a few people and they all seem to say "it should be fine, but then again.. i'd be concerned with your amp shorting out and causing a fire" and "it'll be ok but you wont be really using the full potential of your amps". I got a little paranoid about the whole shorting out stuff and causing fires so i just decided to buy some 4 gauge wire over at ebay and will re-wire the whole thing
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
