Ohm question
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
Question Ohm question
Since I am running two 4 ohm subwoofers in phase and two 4 ohm Subwoofers out of phase, what is the total ohm count of my subs...1 or 2 ohms? Does the ohms change with having two speakers out of phase?
Old Jun 7, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
parrallel is the two speakers (X x Y) divided by (X + Y)
series is the two speakers added X + Y
So you have (4 + 4) x (4 + 4) divided by (4 +4) + (4 + 4)
8 x 8 divided by 8 + 8
64 divided by 16 = 4
You would connect terminal + of subwoofer A to amp positive
terminal - of subwoofer A to + of subwoofer B
terminal - of subwoofer B to amp negative
terminal + of subwoofer C to amp positive
terminal - of subwoofer C to + of subwoofer D
terminal - of subwoofer D to amp negative
Provided that they are wired to the amp in mono mode
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
Huh
I have 4 subs wired in parrallel with two in phase and two outta phase
Old Jun 7, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Phase has nothing to do w/ ohms when wiring.
The real question is why would you run some in and some out of phase. I know it will be a good answer .... haha
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
Joe, check out the pics below in my Member ride's section and tell me if you can figure it out
Old Jun 7, 2003
Ed's Avatar
Ed
I'd assume it's because of the Isobarik configuration he's using?
Old Jun 7, 2003
Ed's Avatar
Ed
arr, you reply to damn fast
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
...you gave it away Ed
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
haha!
Old Jun 7, 2003
Joe is correct, phase has nothing to do with the impedance. Since two of the speakers are backwards, then they are wired backwards. So all that is changed is the direction of the woofer's throw.
terminal - of subwoofer A to - of subwoofer B
terminal + of subwoofer B to amp negative
terminal - of subwoofer C to - of subwoofer D
terminal + of subwoofer D to amp negative
This would yield a 4 ohm load
Old Jun 7, 2003
Regularjoe's Avatar
Forgot about that project. The box turned out good.
Old Jun 7, 2003
fonto's Avatar
The LA Clipper
Thanks! I was gonna mount my amps how you did on a seperate piece of wood...but I got tired of working on the box and to lazy to cut out and carpet another piece of wood...I want to try a fiberglass amp rack as my next project.
anyway, I think there is a simple answer to my question somewhere in one of these replies
...and Rickinthescv, they are dual 8 ohm subs
tuvok
Sep 25, 2015 03:13 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
civic98?
Aug 13, 2015 01:32 AM
Jul 12, 2015 11:54 AM
