Running cable into the trunk
Old May 29, 2003
college kid's Avatar
college kid is an unknown quantity at this point
I just installed my kenwood excellon reciever. I want to hook up my sirius antenna and reciever and I need to run cable from the radio to the trunk. Only I can't figure out how to remove quarter pannels in the back seat. Is there a place that details how all the pannels come out?
Old May 29, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
run it the same way you would run RCA's or a power wire for your amp.. check out the Do It Yourself Section and it gives you all the details you should need.
Old May 29, 2003
VNlilMAN's Avatar
The Standard One
eh i didnt even bother to take it out, i just ran it through... started from the trunk cause i found it easiest
Old May 30, 2003
I just got it all in. I ended up just using a fisher. I just had a real hard time gettin in to go through. Cuz it was a big connector and I kept gettin caught on stuff.
Old May 30, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
You really don't even need to remove the panels. When I ran my RCA cables to the trunk for my sub, I basically ran them under the plastic trim right below the door, then when I got to the end and reached the rear quarter panel, the bottom part, closest to the carpet, isn't really anchored down, so you can wedge the cable under that part of the panel, then stuff it in between the seat and the quarter panel, and into the trunk.
CarStuff
Dec 6, 2020 12:52 PM
Black91civic
Jun 6, 2015 08:15 AM
Dmitri
123
Oct 13, 2005 08:01 PM
NukeSilo
Nov 4, 2001 09:37 PM
