HELP... Hooked up AMP and SUB but Sound ?
Old May 25, 2003
JOO's Avatar
JOO
JOO is an unknown quantity at this point
OK, i jujst got my Performance Teknique 1200 watt 2 channel amp. and 1 12'' MTX Thunder 6000 and I was bangin it for like 2 days and yesterday, my amp just blew and the error LED light came on. I went ot the shop and they said i blew my fuse, so i replaced it. and now my amp works fine with a Green LED light (means ok) but no sound comes to my sub. WTF??? How do you fix this kind of ****.?
Old May 25, 2003
gotti's Avatar
Probably blew your subs.
Old May 29, 2003
VNlilMAN's Avatar
The Standard One
doh you already blew it? who installed it?
Old May 29, 2003
fonto's Avatar
The LA Clipper
Woah, your ish blew already?!?! What ohm sub? Was the amp bridged? Were all of connections ok?
Old May 29, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
check grounding cable...when i had my amp, the amp worked fine but my subs didn't do nething either. I went to best buy and they grounded my grounding wire at a new place, and it worked again. try that
Old Jul 1, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
check the wires on he sub itself. from the terminal to the cone. I know alot of subs have this problem, especially sony
Old Jul 1, 2003
doubledeuce2k2's Avatar
check the sub itself with a 9V battery to the terminals, that will tell you if the sub is indeed blown. it took 3 months but my amp just stopped playing one day and the green light was on (i sent it for service and it took 4 months, but it's fine now). hope you got some warrenty
Old Jul 1, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Let's not revive old threads....this was started a month ago, i'm sure he solved his problem by now.
mjdiaz89
Jun 21, 2016 09:26 PM
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
