triangle enclosure vs traditional "square" box
2k1civic.com O. G.
kinda stupid of me.. but how would i calculate the cubic volume in a triangled shaped enclosure? and would a traiangle enclure of the same volume as a boxed enclose be physically larger or smaller then its boxed counterpart.
image attached
image attached
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
To calculate the volume of a triangle box, start with standard volume calc.
(L * W * H) then divide that total by 2, cause the triangle is half of the cube.
To answer the second part, to get a triangle to match the volume of a certain cube volume, it would be bigger. Because a triangle is only half of the cube.
Better yet, just get a Bazooka. They sound great and don't take up much room.
Originally posted by Bellz
That would only work if at least one corner is at a 90° angle. If there's no 90° angles, you'd have to use one of these formulas.
. You da man!
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
