amp specs to match subs
subs: (2) Alpine 1241 and i wanna run a 2ohm system. what amp specs do i need to fit this. since the subs have 4ohm VC, i dont know how to to figure the watts i need and if it needs to be one channel or two channel. ive spent hours tryin to figure this out to no avail.
thanks in advance
thanks in advance
Im assuming that you have type e's or single voice coil s's on this one, if not, my answer wont be right..... to run them at 2 ohms you have to run them in parallel, and to run them in parallel you have to run them on one channel, so you need an amp that will deliver whatever power you are desiring (i would guess about 400 watts rms....200 to each speaker) on one channel at 2 ohms. Look at mono sub amps, because most stereo amps are not stable to 2 ohms when bridged.
Just wondering- but why do you want to run at 2 ohms? Lower impedence means lower damping factor means sloppy bass. Sure it means more power for less money but it comes at the cost of quality!
alpine sws-1241= 4ohm SVC 200RMS 600max
JohnDoe: 1) i cant afford 'quality'. 2)the human ear cant hear most of the frequencies subs/speakers can reproduce
thanx for input yall
-JAG609
-JAG609
if this were true there would be no need for subs or speakers. the purpose of subs and speakers is to reproduce frequencies that the human ear can hear. Quality doesn't have to be expensive. An installer friend of mine once did his car in all optimus (radio shack brand) stuff. The installation made this extremely cheap equipment sound very good. Sure it wasn't amazing but it was better than a lot of the systems I've heard with much much more expensive equipment.
id prolly go wiht a jbl 600.1, it would be a fairly good match to those subwoofers, will put out 600 rms at 2 ohms, and also 600 rms at 1 ohm, so its super versatile for upgrades in teh future, or changes, possibly, and gives you a healthy amount of power for the woofers, but not OVER healthy, if you knwo what i mean
and it doesnt break the bank either, QUITE affordable on ebay, and even available at places like circuit city, i assume we have a budget to conform to....
Bonobo
Oct 2, 2015 06:58 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
