Is it okay to power a ps1 with the cigarette lighter?
Old May 13, 2003
mos_skeeto's Avatar
mos_skeeto is an unknown quantity at this point
I was thinking of getting a ps2 hooked up to my car but because of it's size I'm thinking of getting a psone (those white tiny playstations) and hooking it up to my car.
Does it fit in the glove box?
Is it safe to run the power from the cigarette lighter to power the ps1 and the sony lcd screen?
Canadian tire is selling a power converter for 29 canadian. This store has a sony car power plug thing for 55 canadian
http://www.futureshop.ca/catalog/pro...=&newdeptid=15
thanks for any help
Old May 13, 2003
WhiteRabbit's Avatar
well, lets see.
your fuse is rated for 15 amps on teh cig lighter. with a little math, P=IV, P = 15 x 12 = 180 watts.
so, with 100% efficiency, you can support 180 watts of draw on the cig lighter.
we use standard 180 watt inverters to run PS2's when we do cars.
check out the power rating on that cable, realize that its not 100% efficient.
its kinda pushing it for OUR supplies, tho it should theoretically work.
but the bottom line is, grab it if its cheap, cause the worst that will happen is youll blow a fuse. then you cna go buy a $.05 cent fuse and a couple bucks of wire to hardwire the thing to yrou car.
Old May 16, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
buy a power converter and cut off the cig plug, wire it up just like an amp, i would get a 300w converter that way you can plug more than one thing on to it. mount the converter in your glove box or under one of your seats. get some visor/ headrest screens. check out some of my pics.
Old May 16, 2003
VNlilMAN's Avatar
The Standard One
eh actually sony makes car adapters for psones... so ya they work fine..
but then i called for ps2s and they said they didnt recommend it. my friend has it hooked up to his cig lighter and its been fine for over a year now. but then again he has a tahoe
Old May 17, 2003
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
I forgot the power inverter wattage for the one I bought, but this is what happened. I used to have a PS1 hooked up to it with no problems whatsoever, it would start every time. I just got a PS2 and sometimes it will turn on when I plug it in, and sometimes it won't. But if I just flip the inverter off and on it will work every time, so I'm fine with it.
Old Apr 11, 2004
ElmoZaPimp's Avatar
ElmoZaPimp is an unknown quantity at this point
I purchased the sony psone inverter and hard wired it to my cig lighter plug hidden behind all the panels, and placed a fuse socket inbetween the source and the unit to prevent any mishaps. It's been good 2 go for over a year now. see my ride 4 some pics
Old Apr 11, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I've had my ps2 and a really small TV hooked up from the cig adapter. I was running a 300 watt inverter, but i did not have the TV and ps2 hooked up for all that long... maybe 20-30 mins total. I didn't run into any problems tho
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
BootyDo
Jul 26, 2015 10:38 AM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
