what do u think of the following setup...[im a NooB..]
Old May 3, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
hey there, i was thinking of the following.
an amp with 500-600watts
10inch sub with 500-1200watts..
ok, i have no idea about this stuff really but i will end up doing most of it myself. one major question that i have is, is my battery gonna be able to run my amp with out anyproblems to other power supplies?
and is the amp good enough with 500watts?
i am not shooting for a really loud system, just one were i have a good kick in it and still have the ability to turn it up a bit if i wanted/need to....
my sound sys. in my HX is stock except for my radio itself, its a sony cd/mp3 with a build in amp(shitty one of course :-D)
i will appriciate any replies, thanks in advance guys!
Old May 3, 2003
just to added on the what i said above..
just in addition,
im thinking about the following speaker
SPL #ML10W
10" 1200 Watt Subwoofer
• 1200 watts power handling
• 160 oz. magnet
• 2” ASV voice coil
• Dual 4 ohm voice coil
• Cyclovent fan cooled
• Die cast aluminum basket
• Black wrinkle finish with Diamond cut
• Spun Aluminum cone
• Chrome front & back plate
• Large rubber slant surround
• One piece, 360º rubber gasket
• Black spider
• Woven tinsel lead through spider
• Chrome screw terminals
• Includes deluxe wood case
• SPL 91 dB
• Sealed box: .5 cu. ft.
• Ported box: 1.4 cu. ft.
• Tuning: 33 Hz
• Port size: 3” (dia) x 11.5” (length)
• # of ports: 1
with the following amp
SPL Series I #SPL4-600 Four-Channel 600 Watt Amp
• Bridged Max Power: 600 Watts
• RMS @ 4 Ohms: 70 X 4
• RMS @ 2 Ohms: 85 X 4
• RMS Mono: 170 X 2
• Full Mosfet Power Supply
• PWM Circuitry
• Full Selectable Crossover Hi / Full / Low
• Three Way Protection Circuit
• 2 Ohm Stable Stereo
• Tri-Mode Capable
• Variable Low Pass 40Hz-120Hz
• Variable Hi Pass 150Hz-1.5Khz
• 18dB Bass Boost @ 40Hz.
• Frequency Response: 10Hz to 30Khz
• S/N Ratio: 97 db
• THD: 0.02%
• System Distress Indicator
• High/Low Level Inputs / Floating Ground
• 4 Gauge Power/Ground Connection
• Gold Plated RCA Connectors
• Line Output
• Dimensions: 11.25" X 2.25" X 11.25"
alright, thanks again
Old May 3, 2003
AntDeezy's Avatar
yur gonna want to get a cap, my lights would dim every time the bass would hit, the cap is a big help, if you get a battery get an Optima battery....
Old May 3, 2003
AntDeezy's Avatar
BTW if you get a chance lose the sony they call it xplod for a reason
Old May 3, 2003
is cap the full name or what does it stand for?
and do you say that i need it because of the amps pwr?
also do u think that the woofer im thinking about has a too high watt range compared to the amps?
oh, and how much would a cap be? :-D
thanks alot!
PS, u want me to just call it xplod? ok, ya know an mp3 player is a mighty fine investment i think. epsecially in the car.
Old May 3, 2003
Ed's Avatar
Ed
A Capacitor is the full name, and you should not need one. I wouldn't get one, especially not yet. Try out the system and see if your lights dim or anything.
THe specs of that sub.. it doesn't seem too good. the numbers are good, bit for $80 (what i found online) It seems like one of those gimmicky brands that aren't that good.
I'd read around the boards a little more. How much are you looking to spend on the sub and amp?
Old May 3, 2003
i am trying to rather keep the price to a min. now that doesnt mean i wanna buy cheap products,
i expected to spend something in the range of 400bucks but would rather spend 300. i dont expect to pay less then that though.
the speakers that i posted i like from the looks, from the number i dont have a very good idea what they mean and ****...
how much do peeps usually spend on a system that is comparrable to what im thinking about?
and how much is a cap?
Old May 3, 2003
oh, also what do u think of the amp? sufficient watts n all?
Old May 3, 2003
Ed's Avatar
Ed
I don't know of that brand, it just looks like one of those cheap brand though :-/ Here's what i'd recommend:
1 12" Adire Audio Shiva ($125) http://www.adireaudio.com/mobile_aud...vers/shiva.htm
1 ~300 watts rms amplifier (~$150) Just get a decent brand 2 channel and bridge it.
1 MDF box (~$25) homebuilt
All of that plus a wiring kit shouldn't run too much more than $300, maybe less if you get a deal on an amp and wiring kit.
Old May 3, 2003
thanks, im gonna check it out!
DaMadScientist
Feb 21, 2007 03:56 PM
REDchirp
Engine Swaps
Jun 28, 2004 07:41 PM
RW_Blaze
May 8, 2004 10:05 AM
RW_Blaze
May 5, 2004 01:37 AM
sean2sean
Feb 24, 2004 04:48 PM
