Trunk Spring Solutions
Old Apr 26, 2003
TBA's Avatar
TBA
Keeping it real...
TBA is an unknown quantity at this point
Arrow Trunk Spring Solutions
I was just wondering on what options I would have with either enlarging, taking out, or just trashing the back trunk springs to put in my 6x9 pioneers in the back. I don't really want to get rid of em but I just want to know the possibilities.
Old Apr 26, 2003
WhiteRabbit's Avatar
if its only a little off, you can screw down the 6x9's and bend the bars a bit, whioch is completely OK.... you just might scratch up yoru 6x9 magnets a bit, which wont hurt performance, either...
if htey are really big, you will need to ditch them or get rid of the torsion bars, which means youll need air struts back there to hold up your trunk lid, which is actually very very heavy.
you cna get air struts at kragen for $20 each, and with the right strut, youll only need one. it wont bend yoru trunk lid so far out of shape that youll notice without looking for it
Old Apr 27, 2003
Connie's Avatar
So air struts will bend your trunk lid but they will work with lifting it instead of springs?
Old Apr 27, 2003
they CAN bend yoru trunk lid, but when you are talking about like a half a milimeter of movement, are you really talking about warping yrou trunk lid?
Old Apr 30, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
I saw a DIY one time for the trunk struts, but can't seem to place it now. Anyone know where it is?
Old Apr 30, 2003
seriously, its not something that needs a step by step. the hardest part is determining the force and length strut you need, and that will change according to the design of your system.
for example, i use my trunk floor as the point of attatchment for my struts. therefore, i can use a LONG low power strut, as the leverage point is pretty good for lift.
Grey used a rather short, high powered arm to lift his, becuase he chose the underside of the rear deck to lift his lid. he needed alot more force to open his than i do mine.
then again, my strut is rather visible....
there are all tradeoffs. i believe his only opens the lid ~85%, mine is all the way, etc etc etc etc.
just sit down with yrou car for awhile, its not too difficult at all to come up with a simple yet effective design! a fun weekend project to do with some buddies, for those less experiencedwith cars...
Old May 3, 2003
outdrsmn80's Avatar
I installed them this morning. Only one of the ball joints had a defect and I have to get it replaced before I can finish it completely. Everything else is done though.
Old May 4, 2003
EnProceso's Avatar
this place might have what your looking for. i'm trying to figure a set up that i wont need to place them on the trunk floor, kinda takes away some of the show value.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
skeener51
Oct 1, 2015 05:56 PM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
