Let me know if this sounds right
Old Apr 22, 2003
zzjkimzz's Avatar
zzjkimzz is an unknown quantity at this point
I'm about to install an Alpine 4 channel 50 watt amp. Let me know if these steps sound right, or if I'm missing anything. I know there is a DIY out on this, but I just want to make sure I have it down right. Thanks a bunch. I'm mounting the amp under my seat, and my HU is connect using a custom wiring harness, and I'm only powering 2 fronts and 2 rears, no sub.
1) Disconnect (-) battery post, connect power wire from (+) post and feed wire through firewall and connect to amp.
2) Remove HU (Sony CDX M730), and from the HU's wiring harness find blue remote turn on wire, cut, splice with remote turn on wire for the amp, and connect to amp.
3) From the stock wiring harness, find the proper speaker wire colors for front/rear +/-, cut, splice with aftermarket speaker wire, and connect to respective amp speaker connections.
4) Connect preamp outs from HU to RCA inputs on amp for fronts and rears.
5) Connect ground wire from amp to solid metal contact.
6) Connect (-) battery post terminal.
7) Connect inline fuse.
Does this sound right?
-Jason
Old Apr 22, 2003
LudlamTheory's Avatar
i boogie for the raindrops
sounds about right, only hting I would do differently is run new speaker wire, but for the most part thats all up to you.
Old Apr 22, 2003
zzjkimzz's Avatar
Thanks! Anyone mount an amp under the passenger seat? Any problems or issues with it? Want to make sure before I drill holes.
-Jason
Old Apr 22, 2003
you gotta take the seat out, and when you take the seat out you gotta unplug some wires, that will set off the srs light on your dash, theres a diy somewhere on how to reset the light.
Old Apr 23, 2003
WhiteRabbit's Avatar
youll be fine using the stock wiring. easier that way, too, rather than rewiring yrou car from scratch
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
