Connecting a nean under seat
Old Apr 1, 2003
AvrilLavigne45's Avatar
AvrilLavigne45 is an unknown quantity at this point
would you use a lisence plate frame under a seat or a straight tube to give light to your car
Old Apr 1, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
tubes. i have 6 inch and they work great. also, you can use whatever you want really, a friend of mine has strobes in his, and they work well too. i suppose the license plate frame would work fine, but i wouldn't think they would put off as much light and concentrate it to a certain spot as well...
Old Apr 1, 2003
WhiteRabbit's Avatar
we put turn signal bulbs under the seats of my buddies 4 runner, they look awesome.
you dont have to spend $20 for stuff thatll cost you $3.50 at kragen!
Old Apr 1, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Rabbit don't the turn signal bulbs get pretty hot tho? I would be afraid that something would get under the seat and it melt or burn.
Old Apr 1, 2003
not if you install it so the bulb is not resting on the carpet.
Old Apr 3, 2003
EnProceso's Avatar
it all depends on how many people sit in your back seat. do lots of people sit back there that you want to impress? then i would go with a LP frame, it would put out glow out all 4 corner but would cost more. only want to show off to people who sit shotgun? then go with a 15" tube. i used zip ties for mouting mine along the bar you use to scoot the seat back and fourth. i also have 2 under the dash, 2 in the side air vents and just put 2 in the middle vents of the dash. i also plan on putting a couple headlight strobes in the 2 middle vents. neon gets addicting, just pick good colors.
Old Apr 3, 2003
our turn signal bulb lights up the entire floor area on each side of the vehicle.
mjdiaz89
Jun 21, 2016 09:26 PM
SuperGroove
Aug 18, 2015 07:55 AM
ballmich
Jul 9, 2015 11:59 AM
