Positive and Negative?
Old Mar 10, 2003
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
So i put in my new speakers, and i noticed something werid. No matter which wire i connected to the speakers, sound still came out fine. I switched back and forth not knowing which wire was postive and which was negative. It didnt even sound different. Anyone know why that is?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]I think when i have some free time ill make sure to connect them correctly just in case. But still it was kinda strange, anyone else find this?
Old Mar 10, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
I have no idea why its like that, but I would keep positive-positive, negative-negative or you may damage your speakers.
Old Mar 10, 2003
Ed's Avatar
Ed
It makes perfect sense that it does. Since it's alternating current, it's going back and forth, and all that the voice coils do is make the cone go forward and backwrd, making the cone vibrate the air to make noise. it'sjust like your wall current (AC), your appliances all work fine with the poer cable going either way (some plugs are polarized with one prong larger tha teh other, but that doesn't matter).
Old Mar 11, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Physics man .....
A speaker moves in and out ..... and as it move current actually switches back and forth that fast. A speaker works by applying voltage one way (and the speaker goes out) ... then applying voltage in the reverse (and it comes back in).
Even though the speaker has a + and - it really makes no difference in sound which way you hook it up.
Where it does matter is when you are using more than one speaker in a system (which is basically everyone now). This is where the term in phase comes in. For the best sound you want all speakers moving out or in at the same time. If they are not coordinated together you get cancellation of the highs and the bass isn't as strong.
Here's an analogy. Consider your subs as hammers trying to break some concrete. The best results will be from them both hitting together at the same exact time although both can work perfectly fine alone. Same with speakers. Working together the bass adds together. Working opposite one another its like you just have one sub hitting at a time.
So technically speaking ..... wiring it either way won't hurt the speaker or affect the sound each speaker itself makes ..... but it will affect the resulting sound the system as a whole produces.
Understand ?
Old Mar 11, 2003
doubledeuce2k2's Avatar
esp. makes a diff with subs where the frequencies are so low, but sometimes can make a difference with your highs too when you have them imaged well.
Old Mar 11, 2003
Vinnie's Avatar
Quote
[hr]Originally posted by: Regularjoe
Physics man .....
Understand ?[hr]
WOW, thanks for breaking it down. I get it now. LOL[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]Thanks[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
solarpunk70
Apr 12, 2016 11:43 AM
danace99
Oct 17, 2015 02:51 PM
68camerors
Sep 24, 2015 06:18 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
