The Re-Birth of my System(Pics)...
Old Mar 10, 2003
AlpineCivic's Avatar
The Re-Birth of my System...
well here's a couple of pictures of what I started to do this weekend and hope to finish by next weekend...
It was a pain in the A** I ran new wire soldered every connection damn it took long but it's coming out good the bad part is that Im nowhere close to finished...
here's my headunit Alpine CDA-9815...
My new processor Alpine PXA-H700 (Not released for sale yet)...
Here's my temporary monitor a CVA-1006 it will eventually be replaced with a IVA-D900...
All the gaps will be covered with fiberglass and body filler...
The trunk is next so stay tuned..
Old Mar 10, 2003
alex053's Avatar
NIIIIIIIIIICE!!!!!! give up some specs on the processor.
Old Mar 10, 2003
Here are the specs for my processor:
PXA-H700MultiMedia Manager™ Digital Signal Processor
FEATURES:
PXA-H700
MULTIMEDIA MANAGER PXA-H700
POWER SUPPLY
CHANGER IN
Ai-NET IN
MIC
CONTROL UNIT
RCA INPUT
OPTICAL INPUT
RCA OUTPUT
SPECIFICATIONS
General
MediaXpander™
Dolby Digital®, Dolby Pro-Logic® ,
Dolby Pro-Logicll® and DTS®
Decoding
8-Channel Output
Auto Time Correction
Microphone Included
Manual Time Correction
6/12/18/24/30dB/OFF Selectable
Crossover
BI-PHANTOM Capibility
Navaigation Mix Input
Rear Mix Capibility
Independently Adjustable Channel Level
Selectable Listening Modes
Standard/Maximum/Late Night
31-Band Graphic Equalizer
17 Band Digital Parametric Equalizer
Digital Time Correction
6 User Programmable Presets
MDAC Digital to Analog Converter
Subwoofer Level Control
3 Optical Inputs
Ai-NET or RCA Inputs
DC-DC Power Supply
S.T.A.R. Circuitry
4 Volt PreOut
Gold Plated RCA Jacks
Number of Bands .............................17 bands (5 Front, 5 Rear, 5 Center, 2 Subwoofer)
Parametric Eq Boost/Cut Range .................................................. ±9dB in steps of 1dB
Parametric Eq “Q” Factor ................................................0. 5/1.0/2.0/3.0/4.0/5.0
Equalizer Center Frequency Range (Front & Rear)* .................................................. ....
Band 1.........20/25/31.5/40/50/63/80/100/125/160/200/250/315/400/500/630 (Hz)
Band 2.......63/80/100/125/160/200/250/315/400/500/630/800/1k/1.2k/1.6k/2k (Hz)
Band 3 .......200/250/315/400/500/630/800/1k/1.2k/1.6k/2k/2.5k/3.2k/4k/5k/6.3k (Hz)
Band 4 ..........630/800/1k/1.2k/1.6k/2k/2.5k/3.2k/4k/5k/6.3k/8k/10k/12.5k/16k/20k (Hz)
Equalizer Center Frequency Range (Center)* .................................................. ............
Equalizer Center Frequency Range (Subwoofer)*...................................... ...................
Time Correction Control Range .................................................0 —20ms (0.1ms steps)
Subwoofer Level Control .................................................. .......................0 to +15dB
Subwoofer Crossover Frequency ...................................20 - 200Hz (1/6 Octave steps)
Subwoofer Crossover Slope .................................................. .....6/12/18/24/30dB
General
Number of Output Channels............8 (2 Front1 L/R, 2 Rear2 L/R, Rear L/R, 1 Center, 1
Subwoofer)
Number of D/A Converters........................................ ...........................................8
DAC Type .................................................. .....MDAC (Multi-level DAC) 26kHz/24Bit
Number of Presets .................................................. ......................6 (User Selectable)
Frequency Response .................................................. ..............20Hz—20kHz (±1dB)
Total Harmonic Distortion .................................................. .................0.02%(at 1kHz)
Channel Separation .................................................. .....................................80dB
Signal to Noise Ratio............................................. ...........110dBA (Digital Optical In)
Input Sensitivity .................................................. ..........850mA (2V for analog 1 only)
Output Voltage .................................................. .................4V (with 10 k ohms load)
Input Impedance......................................... ............................Greater Than10k ohms
Output Impedance .................................................. ......................Less Than 1k ohms
Power Requirement....................................... ...............11—16V DC (negative ground)
Controller Size (WxHxD)mm ..............................................170m m x 46mm x 25.7mm
Controller Size (WxHxD)in .................................................. ..6-3/4” x 1-13/16” x 1”
Main Chassis Size (WxHxD)mm ..........................................260mm x 40mm x 160mm
Main Chassis Size (WxHxD)in ..........................................6-1/4” x 1-9/16” x 6-1/4”
Controller Weight .................................................. .............................180 g (6 oz.)
Main Chassis Weight .................................................. ..............5.1Kg (11lbs. 4 oz.)
Revision-B-06242002
Old Mar 10, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
OK, I want one of those....whats the estimated MSRP, and the release date?
Old Mar 10, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
yes yes...whats the release date and msrp...A friend of my brother GAVE me a pioneer DEQ9200 for free, it's several hundred dollars elsewhere, main main problem, the thing only had 2 volt outputs.....2 volts!!! Lots and lots of hissssssssssssssss...hisssssss.....was very annoying, the alpine you have with 4 volt outs sounds very nice.......
the pioneer, i had in my old car for about 3 months before i took it out, i left college and left the thing under my bed, forgot all about it, the kid that moved into the house i was living in..... in my old room was an electrical engineering major, didn't know jack about car audio, took the pioneer 9200...said wow what is this....he cut the wires off......used the wires....and THREW OUT EVERYTHING ELSE......i could have killed him..plus he's a Cleveland Browns fan..........to make matters worse.....
why oh why did i leave without that EQ, i could have sold it on ebay at the time for like $200.....don't even know the value now
Old Mar 11, 2003
doubledeuce2k2's Avatar
now if you said bengals fan i could understand, but the browns are a team with a respectable history and hardcore fans!
as to the radio, dumb move on his part. but you did leave it [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] and browns fans are normal when they're sober
Old Mar 11, 2003
MSRP is going to be $850.00 and release date is set for April. I love this thing, everyday I love it more and more I recomend it to everyone.
Old Mar 11, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I'm considering the 9815 head unit for my car. I've got a favor to ask - Could you look at it from about the angle I'd be looking at it in the factory location? I'm curious to see if you can see it any better than, for example, the 7894.
Old Mar 11, 2003
aldini's Avatar
aldini is an unknown quantity at this point
There was a DIY on relocating the HU here not too long ago, anybody have it? or how did you do it man?
Old Mar 11, 2003
aldini it wasn't that hard to get the radio there the only thing that takes a little bit of work is making the brackets to mount it and tto get the radio straight...VTECH01EX, I'll look into the angle thing I'll compre both units and get back to you.
Old Mar 11, 2003
jefff's Avatar
jefff is an unknown quantity at this point
You just posted that to make me want one. I hate you. J/K
Old Mar 12, 2003
alex053's Avatar
Cantseeme.............so what exactly do you do for alpine??
Old Mar 12, 2003
civicpride's Avatar
civicpride is an unknown quantity at this point
nice tv
Old Mar 12, 2003
I do Tech Support.....
Old Mar 12, 2003
aldini's Avatar
You had to do some fiberglass work though right CantSeeMe?
Old Mar 12, 2003
Fiberglassing is in the works right now as we speak getting everything in the car done so that I can move on to my trunk.
Old Mar 12, 2003
aldini's Avatar
awesome, I want to see pictures of that final work man
Old Mar 12, 2003
justheman's Avatar
justheman is an unknown quantity at this point
thats the deck I have its tight... I love it... and I am going to put it down in the same area as you... I cant wait to see what it looks like when its done...
Old Mar 12, 2003
VTEC01EX's Avatar
justheman, can you see your deck during the day? That's the only thing I don't like about Alpine's decks, and if it means I can see the display, I'll pop down the extra $100 over the 7894.
Old Mar 12, 2003
justheman's Avatar
I havent had any problem seeing it but it hasnt been that sunny here in oregon... so yea... sorry im not much help
Old Mar 13, 2003
adadani2001's Avatar
adadani2001 is an unknown quantity at this point
Quote
[hr]Originally posted by: VTEC01EX
justheman, can you see your deck during the day? That's the only thing I don't like about Alpine's decks, and if it means I can see the display, I'll pop down the extra $100 over the 7894.[hr]
man i've got the same problem with my alpine deck, i think i'm gonna get a little visor for my deck so i can see it in the daytime.
Old Mar 14, 2003
DMX's Avatar
DMX
DMX is an unknown quantity at this point
Quote
[hr]Originally posted by: adadani2001
Quote
man i've got the same problem with my alpine deck, i think i'm gonna get a little visor for my deck so i can see it in the daytime.[hr]
ahhaha... i was thinking of makin a lil visor to put right over the Hu... damn i hate how i cant see anything in the day... I need to relocate my hu.... DIY instructions pleasse
Old Mar 14, 2003
justheman's Avatar
yea that would be great put up a diy to relocate your head unit!!!!
Old Mar 14, 2003
fonto's Avatar
The LA Clipper
Looks nice Almost makes me want to switch my set-up to 'pine [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
cukaracha
30
Jul 26, 2015 12:01 PM
ZILLA
Jul 13, 2015 04:52 AM
1khilari
Jul 9, 2015 08:12 PM
Ccoop87
Jul 9, 2015 03:26 PM
ZILLA
Jul 5, 2015 05:24 PM
