White sheet protecting door/rear panel, do I dynamat over it or not?
Old Mar 16, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Question White sheet protecting door/rear panel, do I dynamat over it or not?
As most of you know there is a white plastic sheet protecting panels when you remove the moldings around areas of Civic's. I drive a 2001 Civic Coupe and just want to know if I should remove the sheets and dynamat the panel or just dynamat over the sheets? Thanks.
Old Mar 16, 2003
WhiteRabbit's Avatar
you take the plastic off first. the idea is to mass load the panels. make the resonating panels as dead and motionless as possible
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
raymondxcho
Sep 29, 2015 09:00 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
