peepz with sub box
Old Mar 9, 2003
DizWikedCivic's Avatar
peepz with sub box
what do u guys use to hold down the sub box from not moving, i was thinkin of useing those L shape bracket but i dont really want to drill a hole in the box? what are my options
Old Mar 9, 2003
mohawkboom's Avatar
L-Brackets with 5/8" Screws and pre-drill the holes. Otherwise some folks use bungee strap
Old Mar 9, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
if you don't want to drill into the box, you coule get some aluminum strapping, 1 inch wide, and length to size needed, bolt it to the floor on one side, run it over the box as tight as possible, and attach it to the floor on the other side. i did this in a jeep one time cause they aren't really hard to break into, especially in the summer when you have the rag top on. also, if you get ballsy and decide to run a screw through your box, you could run four through the bottom from the inside to the floor, and it wouldn't move, then simply put your sub back in, and it is concealled as well.
Old Mar 9, 2003
jefff's Avatar
jefff is an unknown quantity at this point
Quote
[hr]run a screw through your box, you could run four through the bottom from the inside to the floor, and it wouldn't move, then simply put your sub back in, and it is concealled as well. [hr]
That's a way better idea. just use the same holes if you need to screw it in somewhere else.
Old Mar 9, 2003
666's Avatar
666
666 is an unknown quantity at this point
What about Velcro? If you used the stuff you can get on a roll, it might work.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
h4ldol
Sep 17, 2015 01:25 PM
