Question about Sub setup
Old Mar 4, 2003
2k3silver's Avatar
2k3silver is an unknown quantity at this point
Hi
I own an 03 sedan
and would like to put in a sub that doesnt take up to much room in the trunk, but just gives a little bit of thump. i listen to rap and techno.
I dont want to take out the factory cd player, i just like the way it looks and fits well.
How can i put in a subwoofer and an amp with the leats amount of tearing up the dash.
Can someone suggest the best setup for me, which amp and sub, and how to wire it in?
I heard someone say something about going under the car, for the amp power?
any help would be really aprecaited, I read everypost on this site, and could not find what i was looking for
thanks.
Old Mar 4, 2003
aldini's Avatar
aldini is an unknown quantity at this point
Tap into your rear speakers and use an amplifier with line level inputs, and get whichever sub you prefer, a 10, a 12, whatever you like... For space saving mount the amp onto the back seat
Old Mar 4, 2003
2k3silver's Avatar
where do i buy this?
and what is the best way to connect the amp control line?
and the power for the amp?
can i mount an amp write onto the sub box? the point of this is that i dont want to tear into my car as much as possible.
Old Mar 4, 2003
aldini's Avatar
Many will argue that the vibrations will damage your amp if you mount it to the box and putting screws in your box... ewwww... You COULD DO IT especially as you dont' seem to care much about the SQ you are more interested in your car, go ahead... I have never done that though can't tell you much about it...
Power to the amp I ran it through the passenger's side, just go to a shop if you are worried about tapping into your car, for $25 they can run your power and then you just wire it up to the amp.
The remote wire is not needed for most line level input amps, it just picks up the signal from the speaker wire.
Ground obviously, you have to ground it to a metal in your car
I don't know what stores are by your neighborhood, Circuit City, Best Buy, Good Guys, small audio shops search the Yellow Pages
EDIT: Passenger's side not driver's side
Old Mar 4, 2003
2k3silver's Avatar
http://www.crutchfield.com/cgi-bin/S-V0w5MsRF9fV/ProdView.asp?i=101PL2&id=morephotos&a=&s=0&cc=01
Is this what i want to buy for the line output converter?
So how do i know witch amp will not need a remote wire?
any suggestions of what would be a good setup for me.. for about 250 total
Old Mar 4, 2003
aldini's Avatar
No if you do it like that you'll be hooking it up via RCA so you'll need a remote wire. You need an amp that will take the line level inputs itself. my JBL P80.4 takes line input and doesn't need a remote wire, so I would imagine that the JBL 600.1 also does, check that one out @ ikesound.com or something cuz crutchfield is overpriced. Your best bet is to go to The good Guys and actually look at the amps themselves...
cukaracha
Aug 27, 2015 02:02 AM
Strycker
Aug 2, 2015 08:40 PM
Theshwartz35
Jul 17, 2015 11:13 PM
