AMP wiring on STOCK HEADUNIT???
Old Mar 3, 2003
reytito's Avatar
what do i need to do to wire my amp to the stock headunit? any input would help. thanks
Old Mar 3, 2003
alex053's Avatar
You will need this wiring diagram
and a line output converter to go from speaker wire to RCA output
check this out to.
Old Mar 3, 2003
reytito's Avatar
has anyone done this. used a line output converter and have pics? Correct me if i'm wrong, the best place to access the speaker wires is in the trunk, from the 6X9s...if splicing the 6x9 wires is all i needa do, then thats hella easy!
Old Mar 3, 2003
WhiteRabbit's Avatar
you dont even need that if yoru amp has speaker level inputs, dont orget to disconnect teh rear speakers when you splice them for signal!
for the remote a toggle switch on teh ciggarrete lighter makes a fine remote wire, make sure ou get +12 volts, not ground! wont work too wellif you ground the remote [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 3, 2003
reytito's Avatar
no speaker level inputs thus the line coverter, thanks for the remote wiring tip.
Old Mar 3, 2003
alex053's Avatar
I did in my wifes car....tapped off the rear speakers. No pics though....
Old Mar 3, 2003
reytito's Avatar
[IMG]i/expressions/laugh2.gif[/IMG] your wife has booms in her car? fun.
Old Mar 10, 2003
Jackseric's Avatar
Jackseric is an unknown quantity at this point
Quote
[hr]Originally posted by: WhiteRabbit
for the remote a toggle switch on teh ciggarrete lighter makes a fine remote wire, make sure ou get +12 volts, not ground! wont work too wellif you ground the remote [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
Disconnect them only when in the process of hooking everything up, or permanently disconnected?
Since the cigarette lighter looses power when the key is switched off do you need the toggle switch? Anyone?
Old Mar 10, 2003
2k3silver's Avatar
2k3silver is an unknown quantity at this point
I want to do this same thing.
My amp has the speaker level input
its a box with 4 prongs.
How do i connect the speaker wire to it?? is there an adapater or something that fits in there, if so what is it called
I've been searching online, and cant find any info.
thanks
Old Mar 11, 2003
Jackseric's Avatar
Quote
[hr]Originally posted by: 2k3silver
thanks[hr]
Yeah, my Pheonix Gold came with a little plug that looks like a mini-wiring harness for a head unit. Each wire is labeled for the speaker +/- and one ground connection. It says in the manual: "Maximum hi-level input: 35 watts per channel" so be careful. I'm sure they're all different, but it can't be too far from the max your amp can handle.
Old Mar 11, 2003
Jackseric's Avatar
Since I got my manual out and read it for the first time since I first installed this thing a few years back... now I have a question.
When I ran this amp off my line-level outs from my Sony HU in my last car, it would clip horribly if I turned up the gain too much. That HU had 4 Volt outputs. I just read the following line:
Signal Input Sensitivity: 100 millivolts to 2 volts
Is this possibly the reason for the clipping? Was my line-level signal too much for the amps inputs? It was a low end Pheonix Gold model (QX2350) that I bought when SunTV went out of business for $163. (I went to a custom shop the next day and saw it for $399)
Old Mar 11, 2003
2k3silver's Avatar
I think i'll just get a converter from high to low rca
theres one at walmart for 17 bucks
Old Mar 12, 2003
alex053's Avatar
Quote
[hr]Originally posted by: reytito
[IMG]i/expressions/laugh2.gif[/IMG] your wife has booms in her car? fun.[hr]
she had more than i did until last week...lol. shes not scared to bump 2pac "i aint mad at cha" [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 12, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
get a HU already[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Lopes101
Jun 7, 2015 08:04 PM
jackoncruzpr
May 24, 2015 12:24 AM
smmahan
Apr 15, 2015 08:17 PM
Foom
Dec 6, 2001 01:11 PM
