Fatmating Door?????
Old Feb 23, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Fatmating Door?????
For those who have used fatmat and have covered their door panels as well as rear quarter panels, what do you do about the moisture barrier? Do you take it off, fatmat, and then put it over the fatmat or what? I would really appreciate your help!
Old Feb 23, 2003
doubledeuce2k2's Avatar
that's what i did. i don't care how it looks underneath, and the putty stuff on the plastic is pretty sticky even in the cold, it'll hold on there.
Old Feb 24, 2003
WhiteRabbit's Avatar
have you thought about spraying rubberized undercoating through the door holes? alot easier than putting one small patch in teh one spot you can get through, you cover almost the entire door skin.......
Old Feb 24, 2003
fLyciVic's Avatar
fLyciVic is an unknown quantity at this point
what does fatmatting do?
Old Feb 24, 2003
LudlamTheory's Avatar
i boogie for the raindrops
lowers the resonant frequency of a material and also makes it not deflect as many waves, or, in other words, stops rattle and stops frequencies from bouncing and causing cancellations
Old Jul 11, 2003
orion_squall's Avatar
hi, let's say I get rubber undercoating,
where should I apply it? what little holes?
can I apply it at the "inner side" (the side passenger/driver can't see) of the plastic panel? or we have to apply it at the metal part of the door exposed after the plastic door panel is removed?
Old Jul 11, 2003
the little holes all aound yoru door frame, the idea is to get a nie coat over your entire door skin on the outside.
dont forget to cover yup your windows! dont wanna get any of that nice rubber overspray on them!
krazykoncepts
Sep 8, 2015 09:02 PM
First Car
Sep 8, 2015 08:54 PM
Brad Andrew
Sep 8, 2015 08:22 PM
redcloud
Sep 7, 2015 01:45 PM
ballmich
Jul 9, 2015 11:59 AM
