installing cd reciever
Old Feb 14, 2003
vince44's Avatar
vince44 is an unknown quantity at this point
i have a 2001 civic lx coupe with the cassette reciever. i'd like to swap it out with a cd reciever. so far i am going to get my cd reciever from crutchfield.com, they include the adapters free. how hard is it to swap out the reciever and how long would it take? i have never done this before but i am pretty good with my hands.
Old Feb 14, 2003
nucks's Avatar
nucks is an unknown quantity at this point
depends on how good you are with electronics.....but ordering from crutchfield is a good idea, they have really good step by step instructions and most decks come with a free wiring harness/install kit....if you feel uncomfortable, have a friend help you with wiring, but its not very hard, just take your time
Old Feb 15, 2003
skipbarber's Avatar
the hardest part for me was pulling out the console. dont forget to check and make sure you didnt drop any clips while you were struggling to rip that thing out. Same with the bottom console part too. It's easy, not even that time consuming. just be careful not to scratch anything.
Old Feb 15, 2003
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
If you follow the Crutchfield sheets, you dont have to pull out the whole center console like it says on the DIY on this site. I ordered the Crutchfield sheets for my rear deck, even before there was the Rear deck DIY on this site. You should be fine, it isnt too hard. The only hard part is popping the radio/AC unit out of the dash. I have learned that it if you push from the bottom where you pop off the plug in, its easier. Have Fun.
Old Feb 15, 2003
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
Quote
[hr]Originally posted by: DaveyD
If you follow the Crutchfield sheets, you dont have to pull out the whole center console like it says on the DIY on this site. I ordered the Crutchfield sheets for my rear deck, even before there was the Rear deck DIY on this site. You should be fine, it isnt too hard. The only hard part is popping the radio/AC unit out of the dash. I have learned that it if you push from the bottom where you pop off the plug in, its easier. Have Fun.[hr]
i don't understand how that could be. each part you need to remove has screws that are covered by the next part back. unless you want to break screws i don't see how it can be removed without ripping out the whole center console. i've installed my stereo, then reinstalled to fix a wiring problem (thanks to my brother) then ripped it out of my car and installed it in my new car.
it's not all easy like in my 94 lx where you had two screws next to the glove box and one below and it was out. that install took 15 minutes.
Old Feb 17, 2003
DaveyD's Avatar
Mr. Negative
I linked a copy of the master sheet. Sorry for the bad scan. Click Me
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
