crap! think I fried it..
Old Feb 9, 2003
bboysushi's Avatar
bboysushi is an unknown quantity at this point
Ok
well I used to have 2 wal-mart neons in my interior of my car
one day they died and the switch didnt work, so I decided to re-wire them.
well I got a new switch and got one cable going to the ground, and one cable spliced in (actualy jammed into the back of) the 12volt cig lighter for power.
I wanted to test if the switch worked, so i plugged in the ground and then gently touched the power cable to the power slot.
Then there was a spark and the cig lighter adaptor started to smoke!
So I unplugged everything, and just tried the 12volt cig lighter to see if it worked, and, well unless my adaptors defective, it didnt work.
What did I do? is there a fuse for the cigarette lighter?
Help would be appreciated! I dont care about the neons anymore, but I cant loose my cig lighter!
I routed my neons directly, didnt do it the DIY way with distributors and what not... was there too much power or something..?
Bboysushi
Old Feb 9, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Sounds like you blew the fuse, check fuse #18 in the fuse box under the steering column
Old Feb 10, 2003
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
i ran my neons by tapping into the fog lite wires, no problems yet, have a switch no need to install another, and have been running for 8 months, not that that'll help you any now, but yeah, you may wanna check the fuse...
GolNat
Nov 27, 2018 03:32 PM
bashea
Sep 15, 2015 04:59 AM
mac25
Aug 21, 2015 11:14 PM
brady15
Aug 8, 2015 08:16 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
