amp ground wire
Old Jan 27, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
amp ground wire
i have my amp mounted on my box in the trunk. i had it grounded to a taillight screw but i took it off and grounded it to the left shockabsorber bolt. im just wondering if there is a better place to ground it? where did u guys ground your amp????by the way i have a 02 ex coupe
Old Jan 27, 2003
VNlilMAN's Avatar
The Standard One
wrong forum
i drilled my ground.. well kinda.. there was this small hole, didnt have a bolt to fit it so i drilled enough so that i could fit a bolt through it.. its right behind the 40 split seat..
Old Jan 27, 2003
01civic911's Avatar
01civic911 is an unknown quantity at this point
anywhere that is going to allow contact to the frame is fine, just make sure where you put it is clean metal (ie no paint or anything like that) if there is, sand it down to bare metal to get the proper grounding for your system, it may not seem important, but it is very important
Old Jan 27, 2003
Grey's Avatar
DIY King
Moving to I.C.E. . . .
Please post in the correct forum next time. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 27, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
I have my amps grounded right behind the rear seats
Old Jan 27, 2003
DizWikedCivic's Avatar
you can try the seltbolt or you can pop out the panel by the trunk latch and there bolt where there other wires grounded already
BootyDo
Jun 21, 2016 03:45 PM
robbie374
Jul 7, 2015 02:56 AM
dinsum
May 28, 2015 09:30 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
blackbullet
Dec 1, 2001 03:44 PM
