How do I install a digital cap?
Old Jan 23, 2003
Rollin0n18s
Guest
Posts: n/a
I have no idea what I would need to install and if it is a easy job or not, if anyone knows please let me know thanks
Old Jan 23, 2003
DizWikedCivic's Avatar
you would need ring terminals, just put positive and postive and negative on negative, cut the power wire crimp both end with a ring terminal and screw them in. and do the same thing for the ground, it that simple
Old Jan 23, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
Quote
[hr]Originally posted by: DizWikedCivic
you would need ring terminals, just put positive and postive and negative on negative, cut the power wire crimp both end with a ring terminal and screw them in. and do the same thing for the ground, it that simple[hr]
uhhh your going to blow something up.
put the postive (from battery) on the postivite and then put another postive wire (going to your amps) then take the negative to ground.
battery------(+)----amp
ground
Old Jan 24, 2003
that why you put the negative on first, it would matter if you put the positive wire from the battery first or the positive from the amp
Old Jan 24, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
it doesnt matter how you hook it up, just before you make the final connection put a test light or a resistor between the final connection. i did it between the two posts in the fuse under my hood. you put the test light there so you can charge the cap without creating a huge spark. i dont know if your digital cap is the same as mine, but mine also had a remote connection that i hooked up to the cigarette lighter so the digital display only turned on when the stereo was in use.
Bounddyy
Jul 8, 2015 11:22 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
