right door speaker help
Old Jan 8, 2003
riceboi's Avatar
riceboi is an unknown quantity at this point
there are 2 wires for the left door speaker but why the heck are there 4 wires for the right door speaker?
and i'm also getting engine noise from the right components now
Old Jan 8, 2003
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
no idea??..... there should be only 2 from both sides..... do u have an amp?...... cuz one set could be from the amp and one from the original wires from the deck.
Old Jan 8, 2003
riceboi's Avatar
all 4 wires into the right door speaker harness are orginal wires.. thats why i'm like WTF? why are there 2 on the left side and 4 on the right side?
Old Jan 8, 2003
Ed's Avatar
Ed
well, i'm sure they don't all 4 connect to the actual speaker, so just use the two that are connected to the actual speaker.
Old Jan 8, 2003
riceboi's Avatar
Quote
[hr]well, i'm sure they don't all 4 connect to the actual speaker, so just use the two that are connected to the actual speaker. [hr]
so which two would those be b/c again, the 4 wires plug into the harness, and the harness plugs into the stock speaker. you dont actually see what wires go to where b/c of the harness
its also strange how no one else has 4 wires for the right door speaker
Old Jan 9, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
I know what your talking about. when i saw it i had no idea what the heck they were thinking. i just said screw it and ran new wire
Old Jan 9, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Get a multi-meter, set it to DC-Volts, and crank the stereo up loud....then test to see which wires get signal from the radio.....or you could just run new wire....is kinda a pain, but it will both sound better, handle more power....and just be better.
redcloud
Aug 26, 2015 11:27 AM
swaff39
Aug 11, 2015 07:16 AM
Nalmonte
Jul 22, 2015 09:08 AM
ballmich
Jul 9, 2015 11:59 AM
