Amp Wiring, HELP!!!!!!
Old Jan 7, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Subwoofer Wiring????
Hey everyone, got a quick question. To am not to sure how to wire my JL Audio 12w3 sub, but I have an idea and I need to be sure. There is a positive and negative connection on both sides of my sub. Do I get four pieces of 8 guage wires, solder the wires to both positive and negative connections on either side of the sub and then connect the two positive and two negative at the terminal on the back of the box? Here is the data sheet on my sub, look under the 12w3-D4 section.
Click Here\
Also, outside the box, when I run the postive and negative wire from the back of the sub enclosure to the amplifier, do those need to be 8 guage as well? I would really appreciate your help!
Old Jan 7, 2003
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
if its a dual 4 ohm speaker get speaker wire and connect the 2 negative terminals and get another speaker wire and connect the 2 positive terminals
one positive and one negative terminal should have a white dot or something differant from the others ( im sure if it makes a differance on JL's)
then if there is a differance on one set of terminals those are the terminals that u connect the speaker wire to the terminal on the box
Old Jan 7, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
go to www.rockfordfosgate.com and check out the RFTECH section...complete wiring instructions.
Old Jan 8, 2003
Litespeed's Avatar
Litespeed is an unknown quantity at this point
You don't need to connect the voicecoils with 8 ga wire. 12 ga is good enough. The length of the wire that will connect the voicecoils is short enough that a small diameter wire will not affect current flow. Go to JL's website and look at the PDF's they have for their W3's and it will tell you how to wire your subs. Just make sure you're on the PDF for the ohm load your voicecoils carry.
Old Jan 8, 2003
ZSKCivic01's Avatar
Extreme Member
I did, it shows two way to do it and says each one yields so many ohms when done. One of them you connect both the negative and positive connections and then connect them to the port on the back of the box and another one you connect on of the negative and positive connections and then you connect another positive and negative connections and then just plug them in to the back of the box.
Old Jan 8, 2003
Litespeed's Avatar
I think W3's are 4 ohms so there are 2 ways to wire them... into 4 ohms or 1 ohm. If you have an amp that can handle a 1 ohm load then you can wire them either way. If your amp can't handle a 1 ohm load then wire them into 4 ohms.
Old Jan 8, 2003
Mystic3030's Avatar
W3's actualy come in 2, 4 and 6 OHM...use the rockford website, you punch in how many subs you have, and what ohm, and it tells you exactly how to wire them.
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
