paCoupe Front Door Speakers
Old Jan 4, 2003
Mox's Avatar
Mox
Mox is an unknown quantity at this point
Hey all,
I read the DIY about replacing the front door speakers but I am having problems still. After I got the factory speakers out, I can't figure out how to put the aftermarket ones in it's place. I thought that I could just screw the new speaker into the old mounting bracket but I can't find out how to get the old speaker out of it's housing. Is there a way to do it with the hardware provided or do I have to order the kit from crutchfeild.
Thanks All!
Mike
if you could, please e-mail me with suggestions.
Old Jan 6, 2003
murd0c's Avatar
murd0c is an unknown quantity at this point
I'm trying to do that same thing but I don't know how to get the speeker off!!
Old Jan 6, 2003
STang57's Avatar
STang57 is an unknown quantity at this point
i remember readin of 1 member (forgot name) who put it in the factory housing but he had to customize it.
SCOCHE makes an adapter, u just have to drill 3 small holes on your door.
i have a pair for sale if you want to buy it
Old Jan 7, 2003
666's Avatar
666
666 is an unknown quantity at this point
That plastic bracket is part of the factory speaker. It does not come off. I had to drill new holes in my door.
Old Jan 7, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i used my plastic piece as a spacer...i busted it out...that's how you get the speaker off
Old May 9, 2003
Mox's Avatar
Mox
I ended up just cutting out the speaker itself from the plastic housing, then drilled 3 holes into the housing itself and just mounted the aftermarket speaker right on the factory housing. It worked out just fine.
Old May 9, 2003
dups's Avatar
dups is an unknown quantity at this point
I did it as well, I took a jigsaw and just cut the speaker off of the plastic ring. Worked very well. If you don't care about keeping the factory speakers around for anything just take something and carefully cut around the inside of the plastic ring and punch the speaker out. On the other hand, I wish I hadn't done it because I would like to be able to put my factory speakers back in when I get rid of the car. Oh well.
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
Hondasport01
Dec 6, 2001 11:58 AM
supercivic01
South
Nov 30, 2001 11:27 AM
doublins
Nov 11, 2001 07:01 PM
