Alternator Pulley
Old Dec 28, 2002
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
Alternator Pulley
Any good way to undersize your alternator pulley so that it will spin faster than normal? The pulley is on the alternator itself right. Are they easily removeable? Where can you buy a new pulley that is smaller and that will mesh correctly with the belt. I want to get aem pulley kit and use everything but the oversized alt pulley so i will hopefully cancel out and maybe ever still end up gaining a little HP when all is said and done
Old Dec 28, 2002
mohawkboom's Avatar
Try you locl UAP/NAPA, or any alternator shops..I have a smaller pulley on my alternator so it spins it faster because I was running alot of power and almost all stop and go driving..so I needed the juice at low RPMS"..
Old Dec 28, 2002
Cypher's Avatar
Cypher is an unknown quantity at this point
whats the point in running a smaller pulley to get a faster turn ? Does it make the alt create more power ? i've actually never herd of this [IMG]i/expressions/face-icon-small-confused.gif[/IMG] is this a fix to getting a new high power alt ?
Old Dec 28, 2002
mohawkboom's Avatar
It doesn't produce more power...it produces it's power earlier in the RPM range..under 1500Rpms the alternator has very little output..
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
