tweeters with stock speakers
Old Dec 13, 2002
bboysushi's Avatar
bboysushi is an unknown quantity at this point
I have an LX
we never got tweeters in our cars
if I were to get aftermarket tweeters and install it on my car how would it sound
I dont have an aftermarket speaker system, only an aftermarket HU.
My friend says itll out balance the stock speakers, making more harsh highs and mess everything up.
how true would that be
help would be appreciated
Bboysushi
btw im getting the tweeters that are in the market place, the 300 WATT dome tweeters
Old Dec 13, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
I would not recommend just getting tweeters. Get components. 300 watt tweeters may be nice but being powered off the HU amp will do them no justice. If you get components then your front mids will match better with your highs. But you can set it up the way you are talking of and it will work fine. Your new tweeters won't mess anything up unless you are powering those off an external amp.
Old Dec 13, 2002
bboysushi's Avatar
cool
actually Im confused about your wording there
tweeters will be bad if im just powering it off the HU amp, but I can go ahead and install them without any other components and it should be just fine?
I dont have an external amp, so I will need to connect it to the HU...
Bboysushi
Old Dec 13, 2002
LudlamTheory's Avatar
i boogie for the raindrops
you dont want those tweeters man... theyre some garbage tweeters... who the hell gives away anything good for free?
Old Dec 13, 2002
MangoEX's Avatar
Just Be
MangoEX should not be trusted
i have an EX and replaced my stock tweeters with Polk Momo MM6 ones.... boy a world of difference. sounds crystal clear now... too lazy to install the woofers lol
Old Dec 13, 2002
Bellz's Avatar
I put a set of Pioneer tweets in the doors, along with a set of two-way kenwoods in the stock locations. Sounds great running off the kenwood cd/mp3 hu. I do plan on getting another amp to run the front speakers eventually though. It does sound better amplified, whether they're components or coaxials and tweeters.
Old Dec 15, 2002
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
Quote
[hr]Originally posted by: MangoEX
i have an EX and replaced my stock tweeters with Polk Momo MM6 ones.... boy a world of difference. sounds crystal clear now... too lazy to install the woofers lol[hr]
hey mangoex how did u replace ue stock ex tweeters? i have an EX too and i want to replace the tweeters. are ur new ones installed in the same place as the stock ones?
Old Dec 15, 2002
MangoEX's Avatar
Just Be
All I did was unscrew the stock tweeters, got 2 sets of long bolts with nuts and attached the new Polk tweeter mounts it came with tothe stock housing.
Old Dec 15, 2002
FaintReality's Avatar
FaintReality is an unknown quantity at this point
The crossovers will make or brake the components. Just adding tweets will more than likely sound like ***. You might want to look into a component set, they don't cost all the much and will sound leaps better than the stock speakers if amped.
Old Dec 15, 2002
Quote
All I did was unscrew the stock tweeters, got 2 sets of long bolts with nuts and attached the new Polk tweeter mounts it came with tothe stock housing.[hr]
how do you unscrew the stock tweeters? and how much did the new tweeters cost? thanx
Misfit2613
Jul 30, 2015 09:49 AM
Nalmonte
Jul 22, 2015 09:08 AM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
