How to set gain?
Old Dec 10, 2002
KnightRider2k2's Avatar
KnightRider2k2 is an unknown quantity at this point
How to set gain?
i've had my RF punch 800.2 amp for a while now and never touched the gain. can anyone tell me if i should change it or just leave it? if i need to change it then how much.
Old Dec 10, 2002
mohawkboom's Avatar
if you don't know..don't touch it...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]. Take it to a local shop or a friend who knows alot about audio and have em show ya
Old Dec 10, 2002
Mbow's Avatar
You should have some directions in your owner's manual for the amp. Briefly, from my limited experience this is what you do.
Turn you cd player up to 75-80% of its max volume. Increase the gain until the sound starts to clip (distort) and then back it up a notch. I just played with all my settings on my amp recently. I just experimented with different settings and such. It really made a huge difference in the sq.
Anyhow, I am sure Mohawk will correct me if what I have posted is wrong or dangerous. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 10, 2002
LudlamTheory's Avatar
i boogie for the raindrops
75-80% volume is just an average, it really depends on the radio
in order to find out how high you turn it assuming that you arent running a headunit with 8 or 16 volt preouts, and assuming that your amps are decent amps and allow for a decent amount of voltage, you set the gain on your amps to 0, then turn up the radio until you get distortion... wont be very loud, but youll hear the distortion... whatever volume you get to, turn it down slightly, and thats what you set your gains at... me for example, my radio goes from 0 to 50 on the volume scale, i got distortion at 45-46, so i set my gains around 40-43
Old Dec 10, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
What I do is turn up the volume to 75% then adjust the gain until right before it distorts and that should be perfect.
Quote
[hr]Increase the gain until the sound starts to clip (distort) and then back it up a notch. [hr]
Clipping and distortion are two different things. Clipping is something the amp does. Distortion comes from the speakers so pay attention to the distortion when you do this. You don't want your amp to clip.
Old Dec 11, 2002
DizWikedCivic's Avatar
gain matches your preamp volts on your deck. my default if you have a 2 volt preamp you set the gain to 2/3, if you have a 4.5volt and higher you set the gain all the way. just turn up your volume till it distort then adjust your gain
Old Dec 12, 2002
FaintReality's Avatar
FaintReality is an unknown quantity at this point
Here is a link to the best info. I have ever read on setting gains... http://totoro.efiregate.net Make sure to download the 2 cd test tones... I am gonna se if I can rent a scope to set mine properly, too expensive to buy.
Old Dec 12, 2002
alex053's Avatar
Turning the volume up and adjusting the gain works very well but as a Rockford tech we recomend matching the gain to the output voltage of your headunit. You always want to use more volume from your headunit than gain from your amp. The gain **** only there to get the output you want from lower voltage decks. What is the output voltage of your deck?
Bikergofast
Mar 9, 2016 07:08 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
