How much power does an inverter use...
Old Dec 4, 2002
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
I am wondering, how much power does an inverter use. I like to sit in my car during work, and i just got a dreamcast into it. How long can I SAFTLEY play before I need to worry about my car dying. Assuming it is off or on key position 1.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 4, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i did that experiment once, i was at my brothers soccer tornamet so i plugged my laptop into my inverter and put it in my cigarrete lighter. it lasted and hour before the inverteer shut down. i tried to start the car and couldnt, i need a jump. so i would say 45 minutes at the most
Old Dec 4, 2002
bublik's Avatar
Truehonda.com
Thanks a lot, i guess in cold weather it should be around 35 min. Cool I live in chicago, and i sure as hell dont want to jump in the middle of this crappy winter.
Thanks,
Edward
Old Dec 6, 2002
OmegaStauf's Avatar
OmegaStauf is an unknown quantity at this point
I can only leave my inverter go for about 15 minutes before it kills the battery. This is since it's a 600 watt inverter.
Old Dec 7, 2002
beamer's Avatar
beamer is an unknown quantity at this point
my bat sucks now from the inverter. it has died toomany times
Old Dec 7, 2002
mohawkboom's Avatar
okay...just because it's a 600 watt inverter dowsn't mean it pulls a full 600 watts...it means it can support up to 600 watts....an Xbox uses a fair amount of juice as do LCD's...it's not safe at all to do with a stock battery. Once a battery dies it's never the same again..it's CCA's drop it can;t maintain voltage as well.. For things like this you need a good quality deep cycle secondary battery in your car. usually in the trunk..and use an Isolator to keep your primary/starter battery from losing charge...an optima yellow top is the best choice for this...
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
