Mounting tweeters on A pillar... quick question
Old Nov 28, 2002
MangoEX's Avatar
Just Be
MangoEX should not be trusted
How do I run the wire from inside the pillar cover to inside the door? Im guessing through that rubber hose that connects the door to the body of the car.. but how would I get inside of that? Do i need to remove the dash? If so thats too much damn work. Where did you guys mount your tweeters? Where is thebest place? I was thinking right above the mid-woofer.
Old Nov 28, 2002
mohawkboom's Avatar
Have fun with a wire hanger..it took me 2 hours to feed the wire through...
Old Nov 28, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
remove the kick panel where the hood release is.. and then pop off the panel on the side of the dash that usually covered by the door... feed it through there... dont go to the doors connect it before that.. why would you need to connect to the doors? all the wires run out the rubber connector anyway?
Old Nov 28, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
best place in a sedan is right in front of the door handle.. just use a dill bit and dill a hole... just trace a circle. on the coupe ... you have the option of the inside of the side view mirror.... although they might have come out with one for the sedan too since i have a 2001 i wouldnt know..
Old Nov 29, 2002
Mbow's Avatar
Just run it through the boot. It will be a pain with regular lamp wire so plan accordingly. I had twisted 12 gauge wire that was solid like a power cable so it only took me about 30mins a side.
Tweets: Don't make the mistake of just mounting them where you feel it will be best. Hook everything up and use some tape or velcro to put the tweets in different spots. Listen to music and see where they sound best.
Jeffdp
Aug 5, 2015 11:38 AM
Optimus34
May 25, 2015 11:52 PM
manicEL
Dec 10, 2001 06:33 PM
viper775
Dec 9, 2001 10:52 PM
MooCoW
Nov 9, 2001 05:22 PM
