Subwoofer
Old Nov 28, 2002
DizWikedCivic's Avatar
Subwoofer
i have 2 12" punch hx2, and i have a 1000 watts mono amp. the subs are wired in a 4 ohm load. will my subs blow if my amps is running in 1 ohm.
Old Nov 28, 2002
mohawkboom's Avatar
You amp can't run at 1ohm if the subs are wired for 4ohm.. Ypu don't get to flick a switch and deside the ohm load. The ohm load presented to your amp via your subs determines that.
Old Nov 28, 2002
ok, so the sub deteremined the ohm that it running. so the amp just read as 4 ohm right
Old Nov 28, 2002
mohawkboom's Avatar
Precisely.
Old Nov 28, 2002
thanks cuz i thought i was running at 1 ohm and i thought it would pop my subs if
Old Nov 29, 2002
Phatboy's Avatar
Phatboy is an unknown quantity at this point
I have 4 Memphis 4ohm 10'' subs, wired to 1ohm, My Memphis 1000D Amp, says it delivers 1100watts @Ohm stable.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
wingsfan19
Oct 1, 2015 03:45 AM
wingsfan19
15
Sep 2, 2015 02:15 AM
WLakers
May 4, 2015 06:23 PM
LudlamTheory
Jul 28, 2002 03:45 AM
