installing 2 amps
Old Nov 18, 2002
nolimitrican's Avatar
nolimitrican is an unknown quantity at this point
installing 2 amps
i need help in how to install 2 amps, one is going for the subs, and the other one for the 6x9 [IMG]i/expressions/face-icon-small-confused.gif[/IMG] if someone can help ill appreciate
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
Simple, get a distribution block. Whatever gauge wire you are running to each amp, double the size to the distribution block, then run your power to each amp. You can also get distribution blocks for ground wires as well. Depending on what type of amps and what crossovers, you may only need to run one set of RCA's. One set from the deck to one amp, then out of that amp into the other. Not sure what else ya wanna know, but ask if this doesn't help.
Old Nov 18, 2002
thanks man i really appreciate that, but im running a 760 watt xplod sony, and a 450 watt pioneer, u think that those distrubution blocks will work?
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
Yup, get one that accepts 0 gauge and puts out 2 gauge. Or you can get one that accepts 2 gauge and puts out 4.
Check here.
Old Nov 18, 2002
doubledeuce2k2's Avatar
seek out a circuit city, they are like $30 for 4 way dist block. i ran 4 gauge, split it to 8 and it's fine. i am running 2x150 and a 4x100 at low gain (that's RMS) and it is plenty of juice. 8 gauge can carry like 30 amps, which is fine for your amps. besides, thicker wire can be a b!cth to bend, so keep it simple
Old Nov 18, 2002
andyman97's Avatar
Turbo Guru
That isn't necessarily true. I have a JL 250/1 which is probably at least 400W rms. I started with 8 gauge and the current couldn't keep my cap filled and my amp was clipping out from lack of current. Your wire can never be too big, but it can be too small. Your call tho.
Old Nov 18, 2002
WhiteRabbit's Avatar
jl audio 250/1 puts out 250 RMS. no matter what. unless you drop your voltage below 10 or something, or run it at 8 ohms, something like that.
250 always. solid.
Old Nov 19, 2002
LiKEaFeRiO's Avatar
I asked a while back about how to install a dual amp wiring kit. You dont need the kit but the diagram that RegularJoe made for me should help you out.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] Audio Setup.jpg (40 Kb)
Old Nov 19, 2002
andyman97's Avatar
Turbo Guru
I would argue if I had fact, but I don't have any way to measure the actual wattage. That amp I have is on 1 12w3 and I have the gain all the way down. If I turn it up at all, the sub pops from overexcursion. If you think 250W rms is enough to overexcurt that sub, then maybe you are right, but I wouldn't think so. BTW, it is an awesome amp, the best d block I have ever owned. Oh yeah, and as far as impedence and voltage goes, it doesn't matter. That is the beauty of these amps, no matter what, the output is the same, I agree with you there (R.I.P.P.S.).
Old Nov 19, 2002
LudlamTheory's Avatar
i boogie for the raindrops
popping my friend, is usually a sign of clipping, not overexcursion =) ... also, JL amplifiers, as with most higher quality amplifiers (PPI, etc) all are built for stability and quality, not raw power. To an older audiophile with massive amounts of money, they dont care about power, because theyll just buy a more powerful amp, they care for stability. They want their amp to be pushing 250 watts at all time, no more, AND no less...
Old Nov 19, 2002
actually, 8 gauge can carry closer to 50 amps too, maybe slightly more if it goes a short dist. i.e. from dist block to amp.
and class d circuits draw less current than AB circuits
OptimisticWay
46
Oct 15, 2015 02:16 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
