Head Unit Problems
Old Nov 16, 2002
SoTexTuner's Avatar
SoTexTuner is an unknown quantity at this point
Head Unit Problems
Just finished installing my cd player from my old ride into my civic. I used the wiring harness and everything and the CD player works just fine. However, the keyless entry nor the locks work. Also, everytime I turn the key off and then turn it back on I lose all my presets and everything. I searched but couldn't find a problem quite like this. Any ideas?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 16, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
check your ground wires, or you inputs. its messing that up. what kind of cd player you have?
INJEN
Old Nov 16, 2002
SoTexTuner's Avatar
I have an older model of the Sony CDX-L600X. One problem is that the Constant power wire(yellow) has to be connected to the red power wire to make the cd player come on.
Old Nov 16, 2002
LudlamTheory's Avatar
i boogie for the raindrops
that right there is your problem.... you need a constant power to have these features....
Old Nov 16, 2002
SoTexTuner's Avatar
Is that part of the locking/keyless entry problem also?
Old Nov 16, 2002
Falcon's Avatar
Falcon is an unknown quantity at this point
yep.. like they said, check the const. power wire
it was connected to your stock HU.. and plays an important part in your anti-theft system so ive heard (and so i would imagine it would have to do with the keyless entry/lock/alarm arming system)
sorry i cant tell you much more than that.... you might try giving a phone call to a local car audio store / installer who has worked on 7th gen civics
Old Nov 17, 2002
stackz's Avatar
stackz is an unknown quantity at this point
on some models of civics...like my 98 ex...the keyless entry was built into the factory headunit so in order to keep the factory keyless without going with an aftermarket alarm system you'd have to keep a constant power, switched power, and ground on the stock unit and stuff it down behind the dash. circuit city has the harness for this. I put my old unit down behind where the factory pocket went and designed a nice little custom gauge pod in that area since there wasn't enough room to keep the factory pocket there with the radio behind the console.
-stackz
Old Dec 1, 2002
beamer's Avatar
beamer is an unknown quantity at this point
stomp it into bits
mugenca
Apr 16, 2015 12:15 AM
noodles01
Dec 28, 2001 09:07 AM
ACEM2
Dec 22, 2001 09:14 PM
mwwhonda
Dec 5, 2001 10:52 AM
PimpBot5000
Nov 26, 2001 07:15 PM
