Question about wiring and amp problems
Old Nov 4, 2002
2k2civic's Avatar
I have a question about a friend's system. He currently has the Kenwood Excelon 1000w amp and 2 JL 10W6 subs. Now, the amp is 2 channel 2 ohm stable and the subs are DVC 6 ohm. He has the voice coils wired in parallel and one channel to each sub (so each channel is pushing a load of 3 ohms). For some reason, his amp keeps cutting off. Are the subs wired wrong or can it be one of the settings on the amp? I wasn't the one to install the system, so I don't know where it's grounded or any of that other stuff.
Old Nov 4, 2002
dups's Avatar
dups is an unknown quantity at this point
The remote wire may not be wired good to a good source? just a guess, but I really don't know for sure.
Old Nov 4, 2002
LudlamTheory's Avatar
i boogie for the raindrops
2 ohm stereo? or 2 ohm mono
Old Nov 5, 2002
2k2civic's Avatar
2 ohm stereo
Old Nov 6, 2002
azn2k1civic's Avatar
azn2k1civic is an unknown quantity at this point
i had this problem too. except i had 2 audiobahns at 12 ohm. i went to some local audio store and they told me the easiest way to fix this problem...but not the cheapest...is to buy another woofer (have 3 total)...hook them up in series at 12 ohm each woofer, to match up with my 4 ohm stable amp. so i'm thinking your friend could buy another woofer and hook them all up at 6 ohm and run ur amp at 2 ohm mono. just a thought though
Old Nov 6, 2002
VNlilMAN's Avatar
The Standard One
sorry this is a lil off topic but 2k2civic, where do you shop for your audio stuff? i'm having trouble finding a good shop.
Old Nov 7, 2002
2k2civic's Avatar
I usually buy off the internet - ebay being my primary source. Other than that, I've shopped from Sound Image in Van Nuys, CA...a few places in downtown, LA. IF you need custom installs and stuff, SolarCraft in Burbank, CA is great.
Old Nov 7, 2002
VNlilMAN's Avatar
The Standard One
sound image has the worst service, solarcraft doesnt have much products, what shops in downtown?
Old Nov 7, 2002
WhiteRabbit's Avatar
vinyl, try paris. i really dont know anything about them, but they are the 4rth store in the chain i work(ed) at.
if you want guarranteed good work, drive to san luis obispo. Lombards autosounds in slo has the best installer in teh central coast, i can say that with 100% certainty. has been installing since before i was born. we are a rather expensive shop, however.....
as to the amp cutting, how long does it take? if it cuts, then it has some sort of protect. thermal protection, clipping protection, etc. something is causing it to go into protect, its just a matter of figuring out what.
my earthquake will go into protect after 2-3 hours of hard play. you can bet i can cook an egg on that heat sink at that time tho [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
pincookie1
May 4, 2015 12:22 PM
PimpBot5000
Nov 26, 2001 07:15 PM
klam
Nov 16, 2001 03:36 PM
