box stuffing with cotton or fiber etc.
Old Aug 19, 2002
LudlamTheory's Avatar
i boogie for the raindrops
whats the point of stuffing the box? just curious on the good and bad points of it... im doing my custom trunk sub box tomorrow or tuesday so im curious if its necessary.... i dont know if the type of sub makes a difference, but if it does, then its 2 audiobahn aw1200x subs pushed now by a cheesy flea market amp with about 300 rms, but next month a jbl bp600.1 or 1200.1
Old Aug 19, 2002
STang57's Avatar
STang57 is an unknown quantity at this point
the cotton looking stuff is polyfill. it runs for about a couple of bucks for a pound of it. you use about one pound of polyfill per cubic foot of space in the box and it will slow down the sound waves making it seem as if the box is bigger. i dont know if actual cotton or anything similar will have the same effect. it helps alot with truck wedge style boxes because of the small and tight enclosure, but it also works well with hatch style or normal boxes.
btw, how is the layout of your trunk going to look? i am also considering a custom setup but i dont want to pay a shop to do it. a local audio shop wants to charge $480! their work quality is pretty good, i saw it in my friends car, he bought the car used already with the custom system. i dont have alot of time to experiment and do trial and error on my car, so i really dont want to jump into the project unless im sure that it will work.
Old Aug 19, 2002
ah hah... i've read in the past of people using polyfill, fiberfill, cotton, or even pillow stuffing.... i'm assuming its all the same...
about the trunk, if you go to the DIY section, theres a DIY sub box using the spare tire well, you can remount the tire under the car. my trunk is gonna be a modified version of that one... i need different box dimensions so the floor of the trunk is gonna be raised 3.75 inches instead of the .75 raise in that plan... i think im gonna also make a spiffy little storage space on one side for the jack and another little storage compartment on the other side for other random stuff so it doesnt fly around the trunk and land on my subs.. let me know how many cubes of space you need and i can give you some modified measurements and such... by the way, i'm using mdf not fiberglass... all the stuff to do it is bought... 30 bucks
Old Aug 19, 2002
Ed's Avatar
Ed
Is one suppose to use fiberfill in a ported enclosure? I'm almost positive you are suppose to. I had it in my ported box and I had to use a staple gun to keep it down, so it wouldn't keep spitting little pieces of fiber out the port [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]. Is that alright?
Old Aug 19, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
ive got 2 pound in my 1 cubic ft box [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Aug 27, 2002
NewCivicGuy's Avatar
NewCivicGuy is an unknown quantity at this point
i used regular cotton that my mom uses for making blankets, pillows, etc. that worked just fine.
Old Aug 27, 2002
2k2civic's Avatar
Quote
[hr]Originally posted by: Ed
Is one suppose to use fiberfill in a ported enclosure? I'm almost positive you are suppose to. I had it in my ported box and I had to use a staple gun to keep it down, so it wouldn't keep spitting little pieces of fiber out the port [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]. Is that alright?[hr]
Actually, I hear that it might be a better idea if you were to staple a peice of chicken wire in front of the port.
Old Aug 27, 2002
Subrage's Avatar
Quote
[hr]Originally posted by: 2k2civic
Quote
Actually, I hear that it might be a better idea if you were to staple a peice of chicken wire in front of the port.[hr]
that will create alot of unwanted port noise
Old Aug 27, 2002
you get a funny little whistling... also, if the space between the wires is too small it may create unwanted backflow on the ports
Old Aug 27, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
The polyfill (or whatever) 'tricks' the box into thinking the air in the box is more dense (read: bigger box). The effect would be the same if we filled the box with argon gas (more density than nitrogen). A few years back I was thinking of building an argon gas filled box so it wouldn't take up too much trunk space. eh, polyfill is much easier to keep inside the box. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 28, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
it all has the same effect - polyfill, cotton, whatever else you can find. All of it slows down the sound waves.
Old Aug 28, 2002
xtremeboom's Avatar
xtremeboom is an unknown quantity at this point
anyone know a cheap place to buy poly-fill online? did a search and found nothing but crutchfield $8 a pound
Old Aug 28, 2002
SpeedStar1's Avatar
SpeedStar1 is an unknown quantity at this point
I believe you can just head over to the local fabric store, like Jo-ann Fabric and buy some regular polyfill, the stuff htey use to stuff pillows.
Old Aug 28, 2002
xtremeboom's Avatar
thanks. maybe even wal-mart
Old Aug 29, 2002
I always got mine at WalMart. The stuff is pretty cheap, so unless you're buying literally a TON of the stuff, I wouldn't waste time buying it online.
Old Nov 9, 2003
Ed's Avatar
Ed
I know, this is an old thread.... But, I have the same question again. I'm not sure there was a direct answer. If I built a vented box a little smaller, would putting polyfill in help make it seem larger?
Old Nov 9, 2003
ed, fiberfill in a ported enclosure is actually REALLY effective, check this out:
http://www.win.net/audtatious/audio/fiber.html
Old Nov 9, 2003
fonto's Avatar
The LA Clipper
Joanne's is a good place to get polyfill...but it is a lil pricey there...also a good place to meet chicks if you are single...damn, this is an oooollllllld thread.
Old Nov 9, 2003
LiceLocket's Avatar
LiceLocket is an unknown quantity at this point
anybody try to use this to stuff the trunk? i get tiny rattles in there, and i don't want to use the expandable foam just in case i get airbubbles that i can't fill in b/c it dried up
Old Nov 9, 2003
LiceLocket's Avatar
also, if i have a box already, can i just stuff it w/ this polyfill stuff in the vent w/o taking it apart? are there any risks that the polyfill catches on fire if it gets stuck in the wires (my trunk gets pretty warm sometimes b/c of all the heat of the amps)
Old Nov 9, 2003
Ed's Avatar
Ed
Thankies
Old Nov 9, 2003
doubledeuce2k2's Avatar
poly fill won't conduct electricity, don't worry about fire there. only way that could happen would be if there was arcing on a loose connection, and this stuff would just melt.
i got 20oz polyfill for $4 at joannes. maybe thats above the going rate but i don't stuff many teddy bears
the rule is supposed to be 24oz per cubic foot. you could put it down the vent, but you want the stuff fairly well dispersed (if it is in one big clump, it will make your box smaller rather than work its magic)
Old Nov 9, 2003
LiceLocket's Avatar
would it be better if i just take apart my box and stuff, then reglue? i never did this, and would the wood crack wrong if i pry it open? if its risky, i might as well stuff it w/ a clotheshanger
also, since i might not be able to stuff it all the way in, how "dense" should the filler be?
sorry for so many q's, even tho this thread is old, this is the first tim ei've heard of such technique
Old Nov 9, 2003
if you really want, just rip open some unused pillows and use the stuffing in them. as to ported boxes, teh most effective way is to staple it to the walls of the box, otherwise youll have fuzz flying out of the box on a regular basis
Old Nov 9, 2003
or put a screen over the port
Old Nov 9, 2003
nope.... port noise and the sound is off
Old Nov 10, 2003
DINGALING's Avatar
DINGALING is an unknown quantity at this point
i got mine at walmart. i got the fiberfill batting. it comes in quilt like sheets. i cut it to size, sprayed the box w/glue and stuffed that junk in there. after a day i pulled at the stuffing so it wasn't quite so compact... i really need to get my scanner up and working, so i can post that box building diy...
-DINGALING
Old Nov 10, 2003
WhiteRabbit's Avatar
warbleed has said before that polyfill does nothing unless you stuff the bejesus out of the box.
Old Nov 10, 2003
DINGALING's Avatar
i used to have a resonance coming from my box before i polyfilled. mine's about an inch thick. i'm not sure if it was the polyfill, the spray glue, or a combination of the both, but the resonance is gone.
-DINGALING
Old Nov 10, 2003
i think polyfill helped me. some people don't.
i think capacitors under 5 farads are completely worthless. some people think they are great. point is it's cheap and really won't do any harm. should help cool the sub if not improve sound.
