Crossovers
Old Aug 19, 2002
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
Crossovers
I plan on putting a 4 channel amp to power my internal speakers but what about the tweeters? Do I put 1 channel to the tweeters and the other to the front speakers and the other 2 to the rear (friend told me this sounds ghetto). Or do I buy a external crossover (like the one you get with componets) and run each front channel to the crossover then the speaker?
Old Aug 19, 2002
Ed's Avatar
Ed
Usually, you would use a crossover for each on the channels.
Old Aug 19, 2002
mohawkboom's Avatar
Are you going to amp the OEM speakers?.. or buy new speakers for the rear and component speakers for the front??
Old Aug 19, 2002
I have Infinity reference speakers all around with the stock tweeters but I plan on replacing the tweeters.
Old Aug 19, 2002
mohawkboom's Avatar
why bother the OEM twweters aren't that bad...
Old Aug 19, 2002
I know but if I put a lets say 500 by 4 amp on them wont they blow? Im really just curious on how I should hook all these up?
Old Aug 19, 2002
mohawkboom's Avatar
500Wrmsx4..or 50?... they can handle 40Wrms.. the tweeters are 8ohm so they only see half that power..
Old Aug 19, 2002
I plan on getting the rockford 550x amp for internals and the bd1000 for my box. I get RF stuff for mad cheap.
Old Aug 19, 2002
mohawkboom's Avatar
What's the 550X put out?
Old Aug 19, 2002
68.75 W X 4 @ 4 Ohms RMS
137.5 W X 4 @ 2 Ohms RMS
275 W X 2 @ 4 Ohms Bridged RMS
But remember Rockfords amps are under rated. My friend got this amp and it was rated by rockford to puch 740watts.
Old Aug 19, 2002
mohawkboom's Avatar
Even your infinity references are VERY likely to blow with that power.. get some Infinity kappa components...they come with the woofer..tweeter and crossover network..
Old Aug 19, 2002
My rears handle 300w peak and 100w RMS. My fronts handle 60 peak and 180w RMS. If I tone down the amp they should be fine but how would I hook that up to a 4 channel amp.
Old Aug 19, 2002
mohawkboom's Avatar
ahh no problems then... all you do is wire the tweeter in paralell with the front speaker
Old Aug 19, 2002
so connect the drivers side tweeter and front speaker to one channel the the same for the pass side and then each rear speaker toits own channel?
Old Aug 19, 2002
mohawkboom's Avatar
Yes.. connect the - tweeter wire to the - terminal on your door speaker. the + to the + then wire the amp normally to the door speaker...
Old Aug 19, 2002
Ok sounds good to me. My friend wanted me to get 3 amps. one for the box,one for the speakers and one for the tweeters. Is it just me or would I need a truck to power that? I like your setup better. He also said i could do 1 channel to the tweeters and one channel to the front speakers and the other 2 to the rear.
Jeffdp
Aug 5, 2015 11:38 AM
ZSKCivic01
Mar 8, 2003 05:39 PM
ZSKCivic01
Feb 21, 2003 10:03 PM
NeonNights
Mar 22, 2002 11:44 AM
Slickwillie
Jan 24, 2002 06:39 PM
