Amp setting question?
Old Aug 14, 2002
Heylerds's Avatar
Heylerds is an unknown quantity at this point
I have an Alpine Amp MRV-100m
and there's a Phase switch,
setting is 0 degrees or 180 degrees,
my question is what does it really do?
I tried both setting and I really didn't hear
any difference or just my ears aren't keen on
sound difference.
Need any info on this.
Thanks
Old Aug 14, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
If you switch from 0 to 180 it is making your speakers play out of phase, like if you hook up the positive and negative backwards. It makes your spaekers pull in instead of push out. The only time I ever would use it is in some bandpass applications it may sound better. Otherwise leave it a 0.
Old Aug 14, 2002
Heylerds's Avatar
Ok, thanks for the info.
I'll leave it on 0 then.
Old Aug 14, 2002
tbone323's Avatar
tbone323 is an unknown quantity at this point
the phase **** is intended for time delays. If your subs are closer to you than your front speakers (like in a truck) the sound coming from your subs will reach your ears. You always want your soundstage in front of you thus you want to hear the front speakers first. If you have your subs in your trunk, then you don't need any phase shifting so I would leave it at 0.
tbone
Old Aug 15, 2002
Heylerds's Avatar
I don't know what the setting is right now,
i'll check it later.
Thanks again
roverben
Jan 21, 2019 05:16 PM
jru27
Jun 19, 2015 03:51 PM
jackoncruzpr
May 24, 2015 12:24 AM
PimpBot5000
Nov 26, 2001 07:15 PM
