Easiest place to find ignition wire?
Old Aug 11, 2002
mxxxxxm's Avatar
mxxxxxm is an unknown quantity at this point
Help me,
I've installed a cheapo amp and bass shakers in my gf's 02 civic and need to know where I can find the >Igntion Power 12 Volts BLACK/YELLOW IGNITION SWITCH HARNESS< (thanks for that) . I see the big bundle of wire going up the column but was wondering if there were another option. FYI: I'm keeping the HU stock.
Also, are Civics pre-wired for changers or something? Whats the wires that just terminates in the passenger side of the trunk (under the rug just behind the small fold down seat)???
a quick reply would be appreciated!
Old Aug 11, 2002
WhiteRabbit's Avatar
easiest? thats your ciggarette lighter, that runs on power thats only on with the car on. easiest way to grab a remote lead or neon switch.
Old Aug 11, 2002
mxxxxxm's Avatar
in my car the cig lighter is alway live, is this not the case with Honda Civics?
I guess I could check, right? maybe tomorrow...
Old Aug 11, 2002
in my 1982 accord hatch, the cig is always live, but my cellphone wont charge in my civic unless the car is on. so try and see, i have a 2001, dunno if its the same in a 2002
Old Aug 12, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
Go to the ignition harness its safer and fuse it ... i wouldnt go to the cig lihter with that kinda toy .. i had em [IMG]i/expressions/face-icon-small-puke.gif[/IMG]
Old Aug 12, 2002
crankin, in another post, you said you were a professional...... where do you work?
personal curiosity, cause the cig lighter was designed to take some current flow, is jsut as reliable, what is the advantage of messing with the steering column? ill leave the other thread alone for now.....
Old Aug 12, 2002
mxxxxxm's Avatar
I havent checked on the cig socket yet, but:
I would assume the Ignition wire is fused somewhere, either under the hood or under the steering column. It might be alot easier to get a lead off the fuse block then opening the wire bundle I saw. [If you cant tell, I would prefer not to open that bundle of wires]
Would this information be in a Civic book?
I'm going to check out some stuff this evening.
Old Aug 12, 2002
ill repeat, its far easier to t-tap the cig lighter. should be on the accessory pin anyways.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Strychnine
Aug 15, 2001 07:07 PM
Strychnine
